Application crashing on trying to add map layer from ArcGISServer online
1132
02-05-2011 09:23 AM
SumanChatterjee
I am new to this iOS programming. I have worked with some applications without map. They works fine. But I just started adding a map layer from ArcGISServerOnline following their examples. But my application in the simulator 4.2 crashes with the message "Program received signal SIGABRT" (on debugging) when executing the line marked red below:
- (void)viewDidLoad {
// ----- US highways from ESRI
NSURL *url = [NSURL URLWithString: @"http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StateCityHighway_USA/MapSe..."];
//It crashes on executing the line below
AGSDynamicMapServiceLayer *highwayLayer = [AGSDynamicMapServiceLayer dynamicMapServiceLayerWithURL: url];
[self.mapView addMapLayer:highwayLayer withName:@"US Highways"];
[super viewDidLoad];
I will really appreciate if somebody figures out the problem
Thanks
Suman
SumanChatterjee
Hi All,
I found out the problem. Its because I did not add the -ObjC and -all_load flags in the Other linker flags under Edit Active Target settings.
Thanks
