AGSMultipoint isEqual stuck
1468
03-19-2021 11:52 AM
kris
Hi!
The SDK gets stuck at the following (regardless of the points provided)
let point = AGSMultipoint(points: [])
point.isEqual(to: point)
Cheers,
Kristoffer
rolson_esri
Esri Alum
This issue has been fixed in 100.11.0
Ting
by Esri Regular Contributor
Thanks for reporting this issue. We'll look into it! 🙂
Edit: it is an existing bug 🐛 in the SDK and we'll fix it in the next release!
Many thanks for catching that! 👍
Meanwhile, you may use a temporary workaround like this
```swift
extension AGSMultipoint {
    func isEqualWithoutHanging(to other: AGSGeometry) -> Bool {
        return super.isEqual(to: other)
rolson_esri
Esri Alum
