AGSMapView zoomToEnvelope does not zoom as expected
4064
09-17-2014 07:48 AM
JamesEyre
I am developing an app where I have a small map in a view. I have two points on the map, and I would like to zoom to those two features. I have tried the following, but the map does not zoom to the expected extent.
    AGSGeometryEngine* engine = [AGSGeometryEngine defaultGeometryEngine];
    AGSPoint* gpsPoint = (AGSPoint*)[engine projectGeometry:currentLocation
                                          toSpatialReference:self.mapView.spatialReference];
    NSArray* geometries = [NSArray arrayWithObjects:gpsPoint, point, nil];
    AGSMutableMultipoint* multipoint = (AGSMutableMultipoint*)[engine unionGeometries:geometries];
    AGSEnvelope* envelope = multipoint.envelope;
    [self.mapView zoomToEnvelope: envelope animated:NO];
The two points (gpsPoint and point) make an envelope that is wide but not very high.  The map in the view is pretty much a square. When I call the zoomToEnvelope, I get an extent which does not show my features. It is a small envelope somewhere between my features. I do not see the features on the map.
Is there a function which allows me to zoom to an envelope, that will automatically expand itself to an envelope which contains the whole envelope I desire to zoom to?
Cheers,
Jamie
by Anonymous User
Not applicable
Instead of creating a multipoint, adding points and then using the extent. Use the extent of the points to create a polygon, then just zoom to the polygon you created with the extent of both points.
JamesEyre
I tried this, but I get the same effect. It still zooms to a small extent between the two points. I have verified that the polygon's minx,maxx,miny,maxy are set correctly in the debugger. Any other ideas?
by Anonymous User
Not applicable
Any chance you can share a very small project with the reproducible case? I would recommend to add it on the MapViewDemo sample app and send it my way [email protected]
JamesEyre
I figured out the problem. I set the autoPanMode on the locationDisplay to AGSLocationDisplayAutoPanModeDefault.
self.mapView.locationDisplay.autoPanMode = AGSLocationDisplayAutoPanModeDefault;
Thanks for the help.
