AGSMapServiceInfo not notifying delegate on retrieveLegendInfo
3784
07-24-2012 05:22 AM
DanielMonego
I have an instance of AGSMapserviceInfo which I'm trying to use to retrieve legend info:
-(void)queryLegendWithMapServiceInfo:(AGSMapServiceInfo *)msi {     if(msi.version >= 10.01)     {          msi.delegate = self;         [msi retrieveLegendInfo];     }else {         NSLog(@"Skipping layer [%@]. ArcGIS Service must be version 10 SP1 or above",msi.URL );     } }  - (void)mapServiceInfo:(AGSMapServiceInfo *)mapServiceInfo operationDidRetrieveLegendInfo:(NSOperation*)op {  NSLog(@"Do stuff"); }   - (void)mapServiceInfo:(AGSMapServiceInfo *)mapServiceInfo operation:(NSOperation*)op didFailToRetrieveLegendInfoWithError:(NSError*)error{  NSLog(@"Error encountered while fetching legend : %@",error); }
Unfortunately, this doesn't notify the delegate on either the didFailToRetrieveLegendInfoWithError or on the operationDidRetrieveLegendInfo methods. I've checked this in the debugger and under the Allocations instrument, and msi is neither nil or deallocated. Is there another reason why this call wouldn't even give an error?
DanielMonego
I resolved the problem outside of this sample - the above code was being called by a NSOperation that was being killed before the AGSMapServiceInfoDelegate received the callbacks.
NimeshJarecha
Are you adopting the AGSMapServiceInfoDelegate protocol in your class?
Regards,
Nimesh
DanielMonego
NimeshJarecha
Good to know that you got it working!
Regards,
Nimesh
