AGSIdentifyLayerResult
1922
03-15-2017 10:44 AM
FrederickLee1
What is 'AGSIdentifyLayerResult' and how do I acquire it?
Examples?
DavidLednik
Hi!
This online sample in our GitHub repository should give you an idea how the API is wired together: arcgis-runtime-samples-ios/IdentifyLayersViewController.swift at master · Esri/arcgis-runtime-sample...
regards,
David
FrederickLee1
It looks like AGSIdentifyLayerResult is passively generated from AGSGeoViewTouchDelegate functions rather than 'on the fly'.
DavidLednik
You can not create one yourself, that is correct.
It is only returned as a result of another operation. Or it's a container for those results if you will.
regards,
David
