AGSGraphicLayer graphic attributes
1061
07-25-2013 05:03 PM
DavidMcDonald2
Hi there,
I am curious whether it is possible to change the default behaviour for retrieving graphics in a AGSFeatureLayer when added to a AGSMapView?
Bear with me..
I am currently querying AGSFeatureLayers so that I can return all attributes for each graphic i.e. [query setOutFields:@[@"*"]].  This works fine, but I also need to return the geometry for each graphic in order to sort them by distance from the centre of the map. I have quite a lot of graphics so returning the geometry can become quite inefficient.
If I use the graphics returned dynamically from the visible map region instead, the performance is much better, but these graphics only contain the top two attributes from the feature service layer.
I would like to be able to specify a default query for the AGSFeatureLayer when adding it to a map, as I believe this would be more efficient than manually querying AGSFeatureLayers in this circumstance.
Hope that makes sense.
Dave
DavidMcDonald2
Ok, apologies. The easiest solution for me is to set the outFields in the AGSFeatureLayers to * and then I don't need to make any queries. The app is now running much quicker.
DavidMcDonald2
Hmm, I think I can use the definitionExpression property of the FeatureLayer.. I will give that a go.
DavidMcDonald2
