Accessing a field from a Map Server and populating UITableView
2050
07-24-2024 10:45 PM
AfrozAlam
I am developing an application on Xcode 15.4 & Swift 5.4 using ArcGIS SDK for iOS. I am trying to access the below URL;
https://services.gisqatar.org.qa/server/rest/services/Vector/MunicipalityE/MapServer/0
Extracting the ENAME field and populating a UITableView. This service contains only 8 Records but it takes more than 20 seconds to populate the table. I think, I should take maximum 2-3 seconds.
It would be very much appreciated if someone explain to me why it takes too much time or some thing wrong in my code. The Code is attached herewith for ready reference.
Thanks & regards,
Afroz Alam
Afroz Alam
Ting
by Esri Regular Contributor
Hi Afroz,
After examining this feature service, I found that a large amount of time was consumed by loading the geometry of each feature. If you don't need the geometry in the UITableView, consider the following
queryParams.returnGeometry = false
By setting the query parameter's returnGeometry to false, it will not load the geometry for the feature, which saves big amount of time. Per my test, with this line added, the query takes about 1 second. While it normally takes 5 seconds to fully load.
The full code looks like below. Note that I added a clock to measure the time elapsed for the query.
private func queryMunicipality() {
    let begin = clock()
    print("clock begins")
    let queryParams = AGSQueryParameters()
    queryParams.whereClause = "1=1"
    featureTable.populateFromService(
        with: queryParams,
        clearCache: true,
        outFields: ["*"]
    ) { [weak self] (queryResult: AGSFeatureQueryResult?, error: Error?) in
        guard let self else { return }
        // For measuring time
        let diff = Double(clock() - begin) / Double(CLOCKS_PER_SEC)
        print("Time elapsed", diff)
        if let error {
            print(error.localizedDescription)
        } else if let features = queryResult?.featureEnumerator().allObjects,
                  !features.isEmpty {
            for feature in features {
                let featureDict = [
                    "CODE": feature.attributes.value(forKey: "CODE") as! String,
                    "ENAME": feature.attributes.value(forKey: "ENAME") as! String,
                    "ANAME": feature.attributes.value(forKey: "ANAME") as! String
                print("Attr: \(featureDict)")
Ting
Hi Afroz,
    let begin = clock()
        with: queryParams,
        clearCache: true,
        outFields: ["*"]
        if let error {
                  !features.isEmpty {
                let featureDict = [
AfrozAlam
Hi Ting,
Thank you very much. The problem is solved.
So kind of you.
Warm regards,
Afroz Alam
