Unknown attribute mapoptions [maven]
3769
12-10-2015 07:08 AM
MotiejusViltrakis
I am going through Esri "Hello world" tutorial for android.
In my activitymain.xml (layout) I copy and paste this:
<?xml version="1.0" encoding="utf-8"?>
<RelativeLayout
... (cut out)
  <com.esri.android.map.MapView
   android:id="@+id/map"
   android:layout_width="fill_parent"
   android:layout_height="fill_parent"
   mapoptions.MapType="Streets"
   mapoptions.center="34.056215, -117.195668"
   mapoptions.ZoomLevel="16">
  </com.esri.android.map.MapView>
</RelativeLayout>
Xml file gives me an error: Unknown attribute mapoptions.MapType...
Looks like xml cant find what is mapotions in maven
When i launch the app, it opens, but with black screen where the map should be
Btw I have not downloaded the SDK. Im using Android Studio and the Esri ArcGIS maven repository instead. With dependency 'com.esri.arcgis.android:arcgis-android:10.2.7'
What am I doing wrong ?
MotiejusViltrakis
The problem was, that my device could not connect to the internet, so the app starts with black screen with no errors. It worked with a different device. Topic can be deleted/closed
Although it xml still shows that there is Unknown attribute mapopions. if you type it inside <com.esri.android.map.MapView and you get no "hints" when you press ctrl + space. For hints you have to type it outside <com.esri.android.map.MapView first, then copy paste it back in.
MotiejusViltrakis
