I have an application that uses ActionBarSherlock and Tab navigation with the Android compatibility library. I have 4 fragments that are attached or detached with FragmentTransaction depending on the selected tab.One of the fragment should display a MapView, but I cannot seem to make it work. Do you have examples of using a MapView within a fragment, or any tips for implementing this? Here is my code. One of the things I tried is to simply retrieve the MapView from the XML Layout, but the app just crashes at startup.import com.actionbarsherlock.app.ActionBar;
import com.actionbarsherlock.app.ActionBar.Tab;
import com.actionbarsherlock.app.SherlockFragmentActivity;
import android.os.Bundle;
import android.support.v4.app.Fragment;
import android.support.v4.app.FragmentTransaction;
public class ActionBarTabsActivity extends SherlockFragmentActivity {
@Override
public void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
ActionBar actionBar = getSupportActionBar();
actionBar.setNavigationMode(ActionBar.NAVIGATION_MODE_TABS);
String label1 = getResources().getString(R.string.mapTabLabel);
Tab tab = actionBar.newTab();
tab.setText(label1);
TabListener<MapFragment> tl = new TabListener<MapFragment>(this,
label1, MapFragment.class);
tab.setTabListener(tl);
actionBar.addTab(tab);
String label2 = getResources().getString(R.string.listTabLabel);
tab.setText(label2);
TabListener<ParkListFragment> tl2 = new TabListener<ParkListFragment>(this,
label2, ParkListFragment.class);
tab.setTabListener(tl2);
String label3 = getResources().getString(R.string.filtersTabLabel);
tab.setText(label3);
TabListener<FilterListFragment> tl3 = new TabListener<FilterListFragment>(this,
label3, FilterListFragment.class);
tab.setTabListener(tl3);
String label4 = getResources().getString(R.string.aboutTabLabel);
tab.setText(label4);
TabListener<AboutFragment> tl4 = new TabListener<AboutFragment>(this,
label4, AboutFragment.class);
tab.setTabListener(tl4);
// Restore the current activated tab index
if (savedInstanceState != null)
actionBar.setSelectedNavigationItem(savedInstanceState.getInt("tab_index", 0));
private class TabListener<T extends Fragment> implements ActionBar.TabListener {
private Fragment mFragment;
private final SherlockFragmentActivity mActivity;
private final String mTag;
private final Class<T> mClass;
* Constructor used each time a new tab is created.
* @param activity
* The host Activity, used to instantiate the fragment
* @param tag
* The identifier tag for the fragment
* @param clz
* The fragment's Class, used to instantiate the fragment
public TabListener(SherlockFragmentActivity activity, String tag, Class<T> clz) {
mActivity = activity;
mTag = tag;
mClass = clz;
public void onTabSelected(Tab tab, FragmentTransaction ft) {
mFragment = mActivity.getSupportFragmentManager().findFragmentByTag(mTag);
// Check if the fragment is already initialized
if (mFragment == null) {
// If not, instantiate and add it to the activity
mFragment = Fragment.instantiate(mActivity, mClass.getName());
ft.add(android.R.id.content, mFragment, mTag);
} else {
// If it exists, simply attach it in order to show it
ft.attach(mFragment);
public void onTabUnselected(Tab tab, FragmentTransaction ft) {
if (mFragment != null) {
// Detach the fragment, because another one is being attached
ft.detach(mFragment);
public void onTabReselected(Tab tab, FragmentTransaction ft) {
// User selected the already selected tab. Usually do nothing.
@Override
protected void onSaveInstanceState(Bundle outState)
super.onSaveInstanceState(outState);
// Save the current activated tab index
outState.putInt("tab_index", getSupportActionBar().getSelectedNavigationIndex());
import com.esri.android.map.MapView;
import com.esri.android.map.ags.ArcGISTiledMapServiceLayer;
import android.view.LayoutInflater;
import android.view.View;
import android.view.ViewGroup;
import android.widget.LinearLayout;
public class MapFragment extends Fragment {
MapView map;
@Override
public View onCreateView(LayoutInflater inflater, ViewGroup container,
View layout = inflater.inflate(R.layout.map_test, container, false);
// Retrieve the map and initial extent from XML layout
map = (MapView) layout.findViewById(R.id.map_view);
// Add dynamic layer to MapView
map.addLayer(new ArcGISTiledMapServiceLayer(
"http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"));
return (LinearLayout) layout;
[HTML]<?xml version="1.0" encoding="utf-8"?> <LinearLayout xmlns:android="http://schemas.android.com/apk/res/android" android:id="@+id/map_layout" android:layout_width="fill_parent" android:layout_height="fill_parent" android:orientation="vertical"> <!-- MapView layout and initial extent --> <com.esri.android.map.MapView xmlns:android="http://schemas.android.com/apk/res/android" android:id="@+id/map_view" initExtent="490969 5452639 508730 5473334" android:layout_width="fill_parent" android:layout_height="fill_parent"> </com.esri.android.map.MapView></LinearLayout> [/HTML]
