Hello,I am trying to show Callout for a selected(queried by a single tap) point data (Map service).I believe query part works fine, as I checked that attribute values of a point data are assigned to valuables.That is, "myPopupInfo" has an expected value. However, nothing show up after that.I am not sure whether "popupContent"(TextView) and "rat"(LinearLayout) are correct.I would really appreciate if anybody helped me out...Thank you in advance,Gakumin @Override protected void onCreate(Bundle savedInstanceState) { super.onCreate(savedInstanceState); setContentView(R.layout.map_view); //Set a default tap action as pop-up Map_view.setOnSingleTapListener(new OnSingleTapListener() { private static final long serialVersionUID = 1L; public void onSingleTap(float x_v, float y_v) { Point point = Map_view.toMapPoint(x_v, y_v); // Tolerance: 20 pixel Envelope env_v = new Envelope(point,20*Map_view.getResolution(), 20*Map_view.getResolution()); new setDefaultTapActions_popup(env_v, dmsl_v.getSpatialReference(), point).execute(".../MapServer/0"); } }); } //Query dynamic map service layer by QueryTask(Modified from "PopupInWebmapForViewing.java") private class setDefaultTapActions_popup extends AsyncTask<String, Void, FeatureSet> { private Envelope env_v; private SpatialReference sr; private Point point; public setDefaultTapActions_popup(Envelope env_v, SpatialReference sr, Point point) { super(); this.env_v = env_v; this.sr = sr; this.point = point; } @Override protected FeatureSet doInBackground(String... params) { //Set query parameters Query query = new Query(); query.setInSpatialReference(sr); query.setOutSpatialReference(sr); query.setGeometry(env_v); //For now, max number of returned features is 10. query.setMaxFeatures(10); query.setOutFields(new String[] { "*" }); QueryTask queryTask = new QueryTask(".../MapServer/0"); //Execute query task try { FeatureSet fs_view = queryTask.execute(query); //Get an array of graphics of the query result FeatureSet Graphic[] resultGraphic = fs_view.getGraphics(); View popupView = createPopupView(resultGraphic[0]); Map_view.getCallout().show(point, popupView); } catch (Exception e) { // TODO Auto-generated catch block e.printStackTrace(); } // TODO Auto-generated method stub return null; } private View createPopupView(Graphic graphic) { //Employ "createReportView" of "MyWater" sample of ESRI LinearLayout ret = new LinearLayout(context); ret.setLayoutParams(new LayoutParams(LayoutParams.WRAP_CONTENT, LayoutParams.WRAP_CONTENT)); Object attribute; attribute = graphic.getAttributeValue("Type_Store"); String Type_Store = null; if (attribute != null){ Type_Store = (String)attribute; } attribute = graphic.getAttributeValue("Name_Store"); String Name_Store = null; if (attribute != null){ Name_Store = (String)attribute; } attribute = graphic.getAttributeValue("Open_Close"); String Open_Close = null; if (attribute != null){ Open_Close = (String)attribute; } attribute = graphic.getAttributeValue("Service"); String Service = null; if (attribute != null){ Service = (String)attribute; } attribute = graphic.getAttributeValue("AmountSup"); Integer AmountSup = 0; if (attribute != null){ AmountSup = (Integer)attribute; } StringBuilder myPopupInfo = new StringBuilder(); myPopupInfo.append("Type of Store:\t" + Type_Store); myPopupInfo.append("\nName of Store:\t" + Name_Store); myPopupInfo.append("\nOpen or Close?:\t" + Open_Close); myPopupInfo.append("\nService:\t" + Service); myPopupInfo.append("\nAmount of Supply:\t" + AmountSup); TextView popupContent = new TextView(context); popupContent.setText(myPopupInfo.toString()); popupContent.setTextColor(Color.WHITE); popupContent.setTextSize(TypedValue.COMPLEX_UNIT_DIP, 9); popupContent.setPadding(1, 0, 1, 0); ret.addView(popupContent); // TODO Auto-generated method stub return ret; } }
