Zoom the map to a line
3209
11-25-2014 03:23 AM
HaniDraidi
Is there a way to zoom mapview to a line as is the case with the point? For example, when I want to zoom the map to a point I use: MapView.zoomTo(centerPt, factor), is it possible to do this with a line?
EricBader
Honored Contributor
You can try setExtent on the MapView and pass in the Polyine Geometry itself. That might work the same.
I hope this is helpful.
EricBader
Honored Contributor
HaniDraidi
You are right!
Many thanks Eric
