unfortunately HelloWorld has stoped
5441
6
01-03-2014 08:22 AM
by Anonymous User
Not applicable
Original User: fon123456789
I am trying to use HelloWorld sample file. there is not any error in Problem window and every thing is ok but
when i click on app to run it, a dialog box pop up and say " unfortunately HelloWorld has stoped". please
help me i do not know what is wrong with it?
the error page is attached also.
Thanks in advance
by Anonymous User
Not applicable
Original User: erwi7452
Are you using 10.2?
Please check if you have "libs" folder in your project and contains "armeabi" and "armeabi-v7a" in there
If not, open another project or create new ArcGIS Android Project, and copy the "libs" folder and its content over.
Jamal-eddineOuzemou
Are you using 10.2?
I have this folder with ("armeabi" and "armeabi-v7a") but I have always the same problem
by Anonymous User
Not applicable
if you are running on emulator, please increase the RAM to 768MB
and also did you set "-gpu on" on the run configuration, see here, http://blogs.esri.com/esri/arcgis/2012/05/02/arcgis-runtime-sdk-for-android-v1-1-supports-android-em...
by Anonymous User
Not applicable
Original User: alinadi
1-ensure that you have �??ARM EABI v7a System Image installed
2-configure the Intel Hardware Accelerated Execution Manager by executing the <sdk>/extras/intel/Hardware_Accelerated_Execution_Manager/IntelHAXM.exe program
3-create an Android 4.0.3 AVD and enable the GPU emulation hardware property
4- if you are using eclipse in run configuration find target tab scroll down to see command line and type -gpu on
5- now your problem should be solved
RobertBurke
Ali,
Did this solve the issue?
Thanks!
Rob Burke
by Anonymous User
Not applicable
Ali,
Thanks!
for me this steps worked and yes the issue is solved
regards
