Transform a Point into a Polygon (Square)
1293
02-16-2021 07:25 AM
GuilhermeFernandes
Hello. I am having trouble  to implementing a new functionality in my application.
Based on a point (latitude and longitude),  I want that this point automatically transform into a square, with this lat and long as the center. I'm trying something like this to transform the point:
double ang__ = 0;
double co_x1 = (sin(toRadians(ang__ + 90)) * widthImplement) + point.getX();
double co_y1 = (cos(toRadians(ang__ + 90)) * widthImplement) + point.getY();
double co_x2 = (sin(toRadians(ang__ + 270)) * widthImplement) + point.getX();
double co_y2 = (cos(toRadians(ang__ + 270)) * widthImplement) + point.getY();
But it's not working.
Has anyone already done something like that?
Note: I would like to present width options for this square on the screen.
MarkBaird
You will find it much easier if you convert your point which you want as the centre of your square into a projected coordinate system.  Once you've done that you can offset in metres from the location and things are much easier to understand.
              SimpleLineSymbol simpleLineSymbol = new SimpleLineSymbol(SimpleLineSymbol.Style.SOLID, 0xFF00FF00, 3);
              // a point in a field near London, UK
              wgs84Point = new Point(0,51, SpatialReferences.getWgs84());
              // convert wgs84 (lat / long) into projected coordinate system
              Point wmPoint = (Point) GeometryEngine.project(wgs84Point, SpatialReferences.getWebMercator());
              // size of your square in metres
              double size = 100;
              // easier logic for point of square with offsets in metres
              Point p1 = new Point(wmPoint.getX() + (size / 2), wmPoint.getY() + (size /2), SpatialReferences.getWebMercator());
              Point p2 = new Point(wmPoint.getX() + (size / 2), wmPoint.getY() - (size /2), SpatialReferences.getWebMercator());
              Point p3 = new Point(wmPoint.getX() - (size / 2), wmPoint.getY() - (size /2), SpatialReferences.getWebMercator());
              Point p4 = new Point(wmPoint.getX() - (size / 2), wmPoint.getY() + (size /2), SpatialReferences.getWebMercator());
              // make polygon from points
              PointCollection pointCollection = new PointCollection(SpatialReferences.getWebMercator());
              pointCollection.add(p1);
              pointCollection.add(p2);
              pointCollection.add(p3);
              pointCollection.add(p4);
              Polygon square = new Polygon(pointCollection);
              // Graphic and add to graphics overlay to display it
              Graphic squareGraphic = new Graphic(square, simpleLineSymbol);
              graphicsOverlay.getGraphics().add(squareGraphic);
Not a pretty bit of code, but it should point you in the right direction.
Does this help
GuilhermeFernandes
Thank you so much Mark. Worked perfectly.
