tpk layer in the mmpk do not display
2413
05-25-2018 06:32 AM
VeroniqueXie
Hi:
     I am trying to load a mmpk contains tpk layer, the loading is successful, except that the tpk layer does not diaplay, I use the sample code to load the mmpk, I use the most recent SDK 100.2.1
mMapPackage = new MobileMapPackage(mmpkFile);
// load the mobile map package asynchronously
mMapPackage.loadAsync();
// add done listener which will invoke when mobile map package has loaded
mMapPackage.addDoneLoadingListener(new Runnable() {
    @Override
    public void run() {
        // check load status and that the mobile map package has maps
        if(mMapPackage.getLoadStatus() == LoadStatus.LOADED && mMapPackage.getMaps().size() > 0){
            // add the map from the mobile map package to the MapView
            mMapView.setMap(mMapPackage.getMaps().get(0));
        }else{
            // Log an issue if the mobile map package fails to load
            Log.e(TAG, mMapPackage.getLoadError().getMessage());
   it looks like this, the highway is a vector layer in the mmpk, the .tpk (states layer) is missing.
     I can load it in the ArcGIS explorer, the result is perfect. it looks like this:
 Did anyone experience this problem?
AnttiKajanus1
Could you share the mmpk that you are using?
VeroniqueXie
  Thanks for replying, here is the mmpk I used for test.
AnttiKajanus1
Hi, this seems to work ok on .NET at least assuming this is what you were expecting. I'll ask someone to check it in Andoird.
by Anonymous User
Not applicable
Hi Veronique,
I've tested this on my Android device (ASUS A002) on 100.2.1 and can't replicate the problem. Can I ask what device you're using?
Thanks!
Trevor
VeroniqueXie
Hi, Trevor:
      Thank you very much for your time. I test the code on a Nexus 6p, with android 8.1, and using the SDK of 100.2.1.
