Save Graphics on Map Rotation
4170
03-19-2012 06:26 AM
BrianGustafson
Is there away to save the graphics in the graphics layer on map rotation?  Do I need to store something in a SQLite database?
PatrickBarnhart
Try adding this to the map activity in your manifest xml and see if it does what you need - it doesn't save them anywhere but it does keep your graphic layers from being wiped when the device orientation changes, if that's what you're after.
        <activity android:label="@string/app_name" android:name="your.package.activity" android:theme="@android:style/Theme.NoTitleBar" android:configChanges="orientation">
            <intent-filter>
                <action android:name="android.intent.action.MAIN"/>
                <category android:name="android.intent.category.LAUNCHER"/>
            </intent-filter>
        </activity>
with this I didn't have to use onRetainNonConfigurationInstance()/getLastNonConfigurationInstance() to rebuild the map, onCreate gets called once, etc.  Found it in the HelloWorld example after doing some digging.
DineshMathur
ESRI is about to release next version of the API in this week. This version is expected to be having a sample for workaround for offline editing.
This sample should give you information about how to save features/graphics into a file.
Hope this will be able to solve your problem.
Good Luck
Dinesh Mathur
