Re: oauth2 problems - redirect uri issue
1719
06-08-2017 12:01 AM
KestutisKaladinskas
@Aaron: i am also facing same problem in my android application. Outhview showing same invalid redirect uri error but i'm not able to find the solution yet. please suggest?
AlexanderNohe1
Honored Contributor
Kestutis Kaladinskas
I believe that you could potentially be getting this error if you do not have the redirect URI specified in the applications page in the online developers console.
ArcGIS for Developers
Additionally, can you share any code snippets or screenshots that may help in us understanding the issue?
I would also visit this sample:
https://github.com/Esri/developer-support/tree/master/runtime-android/authenticate-with-oauth
by Anonymous User
Not applicable
Hi Kestutis, The critical bit is to do the following...
Under your Application Settings you need to set Redirect URI as follows....
urn:ietf:wg:oauth:2.0:oob
KestutisKaladinskas
Thanks Aaron. Using above Uri, my problem get fixed
