Null pointer on Mapview when activity OnResume occures
1364
04-29-2021 11:07 AM
JayBowman12
I have a mapView and I'm navigating along a route. I switch to another app then back to my navigation app the onResume fires.  ArcGIS runtime is 100.11
@Override
    protected void onResume() {
        super.onResume();
        if (mMapView != null) {
            mMapView.resume();
The mMapView.resume() is executed and I get this:
Caused by: com.esri.arcgisruntime.ArcGISRuntimeException: Null pointer.: object cannot be null.
at com.esri.arcgisruntime.internal.jni.CoreGeoView.nativeResume(Native Method)
at com.esri.arcgisruntime.internal.jni.CoreGeoView.b(SourceFile:5)
at com.esri.arcgisruntime.a.i.f.g.d(SourceFile:3)
at com.esri.arcgisruntime.mapping.view.GeoView$RenderingThread.resume(SourceFile:4)
at com.esri.arcgisruntime.mapping.view.MapView.resume(SourceFile:1)
at com.thevillages.maplib.MapNavActivity.onResume(MapNavActivity.java:816)
RamaChintapalli
Could you repro the problem with the following sample?
https://github.com/Esri/arcgis-runtime-samples-android/tree/main/java/navigate-route
If so, do you see it on all devices or seeing this behavior on any specific device. Also can you provide the logcat info when you get this error.
Rama
