mapView.PointerMoved functionality (similar to .NET api)?
648
5
09-26-2019 05:17 AM
WesBailes
I use the pointermoved functionality in a .NET app and was wondering if something similar is available for Android? I have an android device that has a smart stylus and would like to handle the movements (pointer over) above the map if at all possible.  I haven't done extensive research as of yet, but curious as to if anyone had some info.  thanks!
WesBailes
Actually figured it out.  setOnHoverListener() did the trick:
mapView.setOnHoverListener(object:View.OnHoverListener {
    override fun onHover(v:View, event:MotionEvent):Boolean {
        val screenPoint = android.graphics.Point(
            Math.round(event!!.x),
            Math.round(event!!.y)
        val mapPoint = mapView.screenToLocation(screenPoint)
        when (event.getAction()) {
            MotionEvent.ACTION_HOVER_ENTER -> hover_text.text ="entered the map at (x: ${mapPoint.x}, y: ${mapPoint.y})"
            MotionEvent.ACTION_HOVER_MOVE ->  hover_text.text = "currently hovering on (x: ${mapPoint.x}, y: ${mapPoint.y})"
            MotionEvent.ACTION_HOVER_EXIT ->  hover_text.text ="no longer hovering, left the map at (x: ${mapPoint.x}, y: ${mapPoint.y}))"
        return false
MarkBaird
Yes, but before I answer the question can you confirm which SDK you are using.  Are you using Android as with Android Studio, or writing a Xamarin cross platform app with Visual Studio?
WesBailes
Mark, thanks for the reply!  Yes using ArcGIS Runtime for Android (100.6) with Android Studio 3.5.
MarkBaird
So the PointerMoved method you've seen is probably a specific method for working with WPF controls.
As a start I'd take a look at this sample to see some basics of interacting with MapViews in Android controls:
Feature Layer Selection | ArcGIS for Developers
It shows you how you can implement a touch listener.
WesBailes
Thanks!  I may check into the setCapturePointerListener method to see what it does.
WesBailes
        return false
