MapView does not display a map (arcgis-android:100.1.0)
4262
10-18-2017 11:01 AM
DavidHoxeng
I have ran the samples from GitHub and the map displays as it should (running the display-map project)
However when I try to implement the same in my own project, the map show this:Just a blank map
Here is my implementation on the activity for the map:
public class ArcGISMapActivity extends AppCompatActivity {
    private MapView mMapView;
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_arcgismap);
        mMapView = (MapView) findViewById(R.id.mapView);
        ArcGISMap map = new ArcGISMap(Basemap.Type.TOPOGRAPHIC, 34.056295, -117.195800, 16);
        mMapView.setMap(map);
    @Override
    protected void onPause(){
        mMapView.pause();
        super.onPause();
    @Override
    protected void onResume(){
        super.onResume();
        mMapView.resume();
Here is the manifest:
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
    package="XXXXXXXXXXXXXXXXXXXXX">
    <application
        android:allowBackup="true"
        android:icon="@mipmap/ic_launcher"
        android:label="@string/app_name"
        android:roundIcon="@mipmap/ic_launcher_round"
        android:supportsRtl="true"
        android:theme="@style/AppTheme">
        <uses-permission android:name = "andriod.permission.CALL_PHONE" />
        <uses-permission android:name="android.permission.INTERNET" />
        <uses-feature android:glEsVersion="0x00020000" android:required="true"/>
        <activity android:name=".activities.MainActivity">
            <intent-filter>
                <action android:name="android.intent.action.MAIN" />
                <category android:name="android.intent.category.LAUNCHER" />
            </intent-filter>
        </activity>
        <activity android:name=".activities.ArcGISMapActivity">
        </activity>
    </application>
</manifest>
The activity is called from the home screen using a standard intent call:
Intent intent = new Intent(getApplicationContext(), ArcGISMapActivity.class);
startActivity(intent);
Seeing that the sample runs, I am guessing that I am missing something, but I can not for the life of me figure out what it is.  Any help would be awesome!
AlexanderNohe1
Honored Contributor
You have the permissions in the wrong location.  They should be outside the application tag.
    <application
            <intent-filter>
            </intent-filter>
        </activity>
        </activity>
    </application>
</manifest>
This documentation specified that is should be contained within the Manifest tag, not the application tag : | Android Developers
I hope this helps!
AlexanderNohe1
Honored Contributor
    <application
            <intent-filter>
            </intent-filter>
        </activity>
        </activity>
    </application>
</manifest>
I hope this helps!
DavidHoxeng
That was it. What a rookie mistake!! That is what happens when you stay up too late coding! I just needed a set of eyes on it.  Thank you so much!
AlexanderNohe1
Honored Contributor
Would you kindly mark mine as the correct answer if it assisted in resolving this issue?
