LocationDisplayManager and Handler Pattern
2599
03-24-2014 03:40 AM
ShaunNicholson
Hello
I am starting to use the Android Runtime SDK and was wondering about recommended coding patterns when using the LocationDisplayManager.  I am relatively new to Android development and still learning so likely missing something.
As far as I can tell its common to use the following pattern when defining handlers:
object.registerListener(handler);
object.unregisterListener(handler);
e.g. during the onResume(), onPause() lifecycle.
However, the LocationDisplayManager provides the setLocationListener() method which I am using as (my Activity implements LocationListener):
locationDisplayManager.setLocationListener(this);
Is there a way to use the registerListener(), unregisterListener() pattern?  How would I detach my class from listening to the events defined on the LocationDisplayManager?
Shaun
teamIgal
You can use the Start() and Stop() methods.
