Load a FeatureLayer with Stored Credentials and Limit Usage to a Map
2056
07-23-2019 05:36 PM
marceloctorres
I'm trying to load a FeatureLayer with Stored Credentials from ArcGIS Online to a Map using ArcGIS SDK Runtime for Android. This is the code:
    private void loadFeatureLayerWithStoredCredentials(String publicUrl) {
        ArcGISMap map = new ArcGISMap(Basemap.Type.STREETS, xCenter, yCenter, zoomLevel);
        ServiceFeatureTable serviceFeatureTable = new ServiceFeatureTable(publicUrl);
        serviceFeatureTable.addDoneLoadingListener(() -> serviceFeatureTableProcess(serviceFeatureTable));
        FeatureLayer featureLayer = new FeatureLayer(serviceFeatureTable);
        map.getOperationalLayers().add(featureLayer);
        mapView.setMap(map);
Attending customer requirements about security and limitations of access, I have to add Limit Usage to the Feature Layer:
And I have to change the code to add Referer Header to the request:
   private void loadFeatureLayerWithStoredCredentials(String urlPublico, String referer) {
        ServiceFeatureTable serviceFeatureTable = new ServiceFeatureTable(urlPublico);
        RequestConfiguration request = new RequestConfiguration();
        request.getHeaders().put("Referer", referer);
        serviceFeatureTable.setRequestConfiguration(request);
Since then I began to get this error:
Error: com.esri.arcgisruntime.io.JsonEmbeddedException: You do not have permissions
to access this resource or perform this operation.
Can somebody help me?
Marcelo César Torres
marceloctorres
The answer is very simple but strange, in this line:
The key must be in lowercase, I mean: "referer" that's all. >(
marceloctorres
