Is Geofencing support provided in ArcGIS Runtime SDK?
1379
10-05-2017 02:11 PM
SharjeelAhmed
I looked around ArcGIS Runtime SDK for Android v100.1.0 but couldn't find anything on Geofencing. Is there any complete or partial support for Geofencing in Runtime SDK for Android?
Tags (1)
AlexanderNohe1
Honored Contributor
There is support but it is a solution that would have to be built using the available resources in the documentation.  It is not out of the box.
AlexanderNohe1
Honored Contributor
Here is a sample that uses 10.2.7 to create a geofence:
arcgis-runtime-demos-android/2016-DS/LocalGeofence at master · Esri/arcgis-runtime-demos-android · G...
Using this as a rough guide, you can likely write a version that suites your needs for runtime 100.x
Hope this helps!
