Install ArcGIS SDK for Android
4494
03-13-2012 12:10 PM
SiminYou
I am trying to install ArcGIS SDK by following the tutorial. However, after installation I don't have the wizard of "ArcGIS for Android". But I can run Android samples from google. I am not sure where I did wrong.
My environment is:
Eclipse 3.7.1
ADT plug-in 16.0.1
Thanks for your answer.
SimonKlein
did you follow this tutorial?
Installing the ArcGIS Runtime SDK for Android Eclipse Plugin
ArcGIS Runtime SDK for Android is a custom plugin for the Eclipse IDE designed to offer you a robust integrated environment to build ArcGIS Mapping applications for the Android platform.
Download the ArcGIS Runtime SDK for Android update site
Start Eclipse, then select Help > Install New Software....
Click Add, in the top-right corner.
In the Add Repository dialog that appears, enter "ArcGIS 4 Android Plugin" for the Name then click the Local button and navigate to the previously downloaded plugin
Click OK
In the Available Software dialog, open up the 'ArcGIS for Android' category to see the items available. If 'Group items by category' is unchecked you will see the available items listed.
Select the checkbox next to ArcGIS for Android Core and click Next. Addtionally, select the checkbox next to 'ArcGIS for Android Doc and Samples' to include the Android Samples and integrated Help system.
In the next window, you'll see a list of the tools to be downloaded. Click Next.
Read and accept the license agreements, then click Finish.
When the installation completes, restart Eclipse.
Also, did you install the android SDK BEFORE the ArcGIS SDK?
SiminYou
Thanks for your reply, Simon.
Yes, I have installed Android SDK first, and I have tried Android samples from Google. After that I was trying to install ArcGIS for Android package using the same tutorial you mentioned.
SimonKlein
Hm that's strange.
Maybe starting from scratch?
SiminYou
I unintalled the ArcGIS for Android, and installed the SDK by running eclipse as administrator which solved the problem!
Thanks again for your replys, Simon.
Hm that's strange.
DeniseKing
If a post provides the answer to your question, then we encourage you to mark the post as "the answer" by activating the green check mark  right of the post. You can also "vote" on posts that you find helpful by clicking the blue caret mark. More information about the ArcGIS Discussion Forums MVP Program found here.
Thank you,
Esri Support
