Improve default gesture for tilting camera in a scene ?
938
02-21-2020 04:03 AM
NickCalv
Hello,
I've been getting a lot of feedback from testers of my app that the tilt gesture is not intuitive, bordering on impossible to use for some people.  Most are struggling with the requirement to vertically-align the two fingers doing the drag motion, and are more accustomed to being able to drag to tilt even when their two fingers are vertically offset.
Also, many people expect to be able to tilt and rotate the view at the same time, but currently this is not supported by the ArcGIS SDK.
Does ESRI have any intention to change this?  Is there any way to modify the sensitivity of the gesture to mitigate these problems?
Thanks
by Anonymous User
Not applicable
Hello!
I don't believe there are plans to change the behaviors, but the API is flexible enough that you could change the behavior to meet your user's needs. Just override the DefaultSceneViewOnTOuchListener like here:
arcgis-runtime-samples-android/MainActivity.java at 81a23fb7814cebe376bf3979a70a599c66742679 · Esri/...
If your case, you'd want to override the onTwoPointerPitch motion event.
Hope this helps!
Trevor
