I want to populate map from json data in Android, but can't find any relevant information/method to do so. Does anyone over there have any idea ?
5279
02-05-2015 10:25 PM
shailendrarajawat
the format of json is
"currentVersion": 10.01,
"serviceDescription": "",
"mapName": "Layers",
"description": "",
"copyrightText": "",
"layers": [
   "id": 0,
   "name": "",
   "parentLayerId": -1,
   "defaultVisibility": true,
   "subLayerIds": null,
   "minScale": 0000,
   "maxScale": 0
"tables": [],
"spatialReference": {},
"singleFusedMapCache": false,
"initialExtent": {
  "xmin": ,
  "ymin": ,
  "xmax": ,
  "ymax": ,
"fullExtent": {
  "xmin": -1.0547305
I know we can create layer using  ArcGISDynamicMapServiceLayer(url) constructor, but i have json instead of URL.
iOS sdk provides this facility
AGSDynamicMapServiceLayer *dynamicLayer = [[AGSDynamicMapServiceLayer alloc] initWithJSON:mapJson];
so i believe it should be possible for android as well. But have no idea.. how
MengyiGuo
Hi Shailendra,
I'm afraid right now we don't have a similar method in Android to do so. Initialization parses Json from REST end point.
KeithTurner
We're showing data from a JSON web service on our map.  We grab the json from our web service.  Take that and reformat it into the json format used by arcgis server (documented here - ArcGIS Server REST API ).  Take the resulting json, feed it into FeatureSet.fromJson(JsonParser) to get a featureset and add that to a graphicslayer.
It's not simple/pretty, but it does the job.
Keith
