How to Load Map from local saved .vtpk .geodatabase and .mmap file
2126
11-09-2023 06:48 AM
GautamBisht007
I want to know when we download map after selecting the download area, it create 3 files (.vtpk .geodatabase and .mmap file) to our local storage and resources. need help to load map from these local saved files. I want to download multiple maps and showcase all saved from local saved in a list on tap I want to local selected downloaded map in MapView
Shubham_Sharma
We have sample apps to help demonstrate the workflow of loading a locally saved vtpk, geodatabase, or a mmpk file using the ArcGIS Runtime for Android SDK:
  • Export vector tiles: Link
  • Create mobile geodatabase: Link
  • Open mobile map package: Link
Or check out our documentation tutorial pages: Work with offline data (link)
GautamBisht007
Hi Shubham I need something like load the baseman(downloaded) then attach layer to it. can you help me something like that?
Shubham_Sharma
@GautamBisht007 You can load a vector tile package file (.vtpk) which contains your local basemap, and then load the layer.
  • Snippet to load an ArcGISVectorTiledLayer as the basemap: Link
  •  To add a feature layer to a map: Sample
