How to freehand draw in runtime 100.1
2367
6
07-13-2017 02:54 AM
wusheng
如何在runtime 100.1 中freehand draw
Tags (1)
AlexanderNohe1
Honored Contributor
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
        MapView mapView = (MapView) findViewById(R.id.mapView);
        ArcGISMap map = new ArcGISMap(Basemap.Type.DARK_GRAY_CANVAS_VECTOR, 0, 0, 4);
        mapView.setMap(map);
        SketchEditor sketchEditor = new SketchEditor();
        mapView.setSketchEditor(sketchEditor);
        sketchEditor.start(SketchCreationMode.FREEHAND_LINE);
This is a basic implementation.  It may require additional configuration on your end to suit your needs.
wusheng
Thank you very much
wusheng
But I found sketch conflict with mapview's DefaultMapViewOnTouchListener
AlexanderNohe1
Honored Contributor
Yes, I noticed this too and believe this may be part of the design.  I will have to speak with my team regarding this.
AlexanderNohe1
Honored Contributor
If you are okay with me asking, there may be another solution for what you are attempting to do.  Is there something you were hoping to do with the touch listener?
wusheng
I want to do a military plotting function
