how do i zoomIn zoomOut map during initial load for perticular area
1048
09-29-2019 10:37 PM
NishidhKhanapara
I want to zoomout or focus  perticular Area of map have some places with markers during 1st time map load.. even it should be zoomin and zoomout deeply.How can I...
JonL
by Esri Alum
Esri Alum
Hi Nishidh,
You can use the method:
map.addDoneLoadingListener(Runnable listener)
You can then set the viewpoint once the map has finished loading using one of the many ways elaborated in this sample:
arcgis-runtime-samples-android/java/change-viewpoint at master · Esri/arcgis-runtime-samples-android...
NishidhKhanapara
Hello,
Still You can't understand my problem.
I have recently fetch issue in particular latitude and longitude position to add marker,and marker which can be zoom in and zoom out in particular lat long wise.
