how can i add a point on the map?
2753
06-24-2014 09:02 PM
Mohammad_NaserSobhan_Noorzai
I need to add points on the map from static gps coordinations please help me, the gps is float or double but in Point(int, int) it's int?
please help me.
ShellyGill1
It sounds to me like you may have imported the wrong Point class, there is a number of Point classes around in standard libraries. Check the imports at the top of your class file, you might find you have:
import android.graphics.Point;
Delete that one (assuming you're not using this Android graphics point elsewhere), and replace it with the ArcGIS Runtime SDK for Android Point class import, using a statement like this:
import com.esri.core.geometry.Point;
And then go back to your Point class declaration and you should find you now have different constructors for your Point, and the x, y parameters will be doubles. Its easy to accidentally add the wrong imports sometimes, and different IDEs have different shortcuts and commands to automate adding the imports.
Hope this helps,
thank you so much, you are right.
but can you please bring a sample code how can i add a point on the map using (GPS Coordination).
thanks man
ShellyGill1
There's a few samples you might find useful - you can try out the Nearby sample to see how the LocationDisplayManager is used to set a LocationListener to get onLocationChanged callbacks that give you GPS updates:
https://developers.arcgis.com/android/sample-code/nearby/
You might find the AddCSV2GraphicsLayer sample useful to show you how to add a series of x,y coordinates to a GraphicsLayer in a map - in this case you can see the coordinates are coming from a CSV file, so you'd need to take this and change it to work with your GPS coordinates instead:
https://developers.arcgis.com/android/sample-code/addcsv-file/
Hopefully these two should give you some pointers, depending on what you actually want to do with the GPS locations.
