GraphicsLayer  getGraphicIDs    Error
6786
11
06-16-2013 06:24 PM
yongbolee
Running time Eviroument is : Arcgis SDK for android 2.0
  problem description:
        when i calling   GraphicsLayer's getGraphicIDs method will get a Error like-[ATTACH=CONFIG]25297[/ATTACH]
        this mapView will black screen at the same time.
   i want to know if this problem is a bug for 2.0 SDK?
  who can help me ??
  i have not occur it if user Arcgis SDK for android 1.0.
AndyGup
Have you tried upgrading to ArcGIS Runtime for Android v10.1.1?
-Andy
Yunus_SupriadiWijaya
i have the same problem using ArcGISAndroidSDK_v10.1.1-u1 from http://www.esri.com/apps/products/do...downloadid=982
but the error was different
08-15 20:10:10.505: E/MapCore(823): Frame_buffer_OGL::init_ FrameBufferOGLTexture2D: gl error = 502
08-15 20:10:10.558: A/libc(823): Fatal signal 11 (SIGSEGV) at 0xdeadbaad (code=1), thread 836 (Thread-78)
AndyGup
Yunus, can you reproduce that consistently? I agree there should be any Signal 11's. If it is reproducible can you please open a support ticket? That way we can get all appropriate details and track this.
DanO_Neill
Agreed!  Please share the reproducible code here as well if you can.
i tried the PopupInWebmapForEditing sample.
i'm using
1. Eclipse Java EE IDE for Web Developers. Helios Service Release 2 and Android Developer Tools v22.0.5-757759
2. ArcGISAndroidSDK_v10.1.1-u1.zip.
3. jdk-7u25-windows-x64
i think the problem at the  "int[] ids = featureLayer.getGraphicIDs(x, y, tolerance);"
protected Graphic[] doInBackground(ArcGISFeatureLayer... params) {
for (ArcGISFeatureLayer featureLayer : params) {
this.featureLayer = featureLayer;
// Retrieve graphic ids near the point.
if (ids != null && ids.length > 0) {
ArrayList<Graphic> graphics = new ArrayList<Graphic>();
for (int id : ids) {
// Obtain graphic based on the id.
Graphic g = featureLayer.getGraphic(id);
if (g == null)
continue;
graphics.add(g);
// Return an array of graphics near the point.
return graphics.toArray(new Graphic[0]);
return null;
DanO_Neill
I am not able to reproduce with v10.1.1-u1. I did not try with v2.
  1. Did you update the sample?  Use your own data?
  2. What version of the Android Support Library are you using?
  3. What device are you deploying to?
Thanks for your quick response, Mr. Dan ONeill
Did you update the sample?    i used the ArcGIS for Android version 10.1.1.201306271100 sample
Use your own data? No , i used the original code using online data
What version of the Android Support Library are you using?  Android Support Library 18
What device are you deploying to? Android 4.3 Jelly Bean
DanO_Neill
What physical device are you deploying to, e.g. Galaxy Nexus, HTC, etc. I am still trying to reproduce.
Samsung Galaxy W I8150 and android emulator
