Generate a offline geodtabase
3500
04-04-2014 04:11 AM
zijianzhu
Hi, I'm currently use the ArcGIS Runtime SDK for Android. I want to generate a offline geodatabase from online feature service.
I use the code of the tutorials to do this job. However, I found that several services can not be generated to local geodatabase,
such as " http://sampleserver6.arcgisonline.com/arcgis/rest/services/Wildfire/FeatureServer "
           "http://sampleserver5.arcgisonline.com/arcgis/rest/services/EmergencyFacilities/FeatureServer"
           "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StateCityHighway_USA/MapSe... "
but some other service can be generated to geodatabase like
            " http://services.arcgis.com/P3ePLMYs2RVChkJx/arcgis/rest/services/Wildfire/FeatureServer"
I really do not know the differences among them. I want to publish a webservice on the intranet which can be generated to local
one and it is able to be modified. Could someone help me? thanks.
RobertBurke
Hi
When I look at the rest endpoint for the Wildfire feature service:
And scroll all the way to the bottom, I can see the Sync and Replica Operations are available:
Supported Operations:   Query   Apply Edits   Create Replica   Synchronize Replica   Unregister Replica
The other feature services you mention only show Query and Apply Edits.
Please have a look at this Guide topic Create and Offline map:
https://developers.arcgis.com/android/guide/create-an-offline-map.htm
One of its topics describes 'a sync-enabled feature service' and creating one.
Please let me know if this helps get you any closer to solving the issue.
Rob Burke
zijianzhu
Hi
Yes, I solved the problem, thank you 😉
