Field ordering of IdentifyResult
3289
04-27-2012 06:39 AM
danielconrad
I published a service on ArcGIS Server where I specified an order on my layer's fields in my mxd.  When I execute an identify task using the android sdk, I noticed that my identify results do not maintain the ordering of the returned fields and instead return the attributes in what appears to be a HashMap.  I noticed that the json returned by the identify service does have the fields ordered properly for each identify result.
I was just wondering if this was a known issue that will be fixed in later releases, or if there is another method I am suppose to be using to acquire the ordering of fields for and identify result.
Dan
RobertHarris1
I am having the same issue. I was wondering if there has been any resolution?
ShaneCarey
Hi Robert/ Daniel,
I have published a Mapserver and I try copy and past the url into the Identify task sample. The layer displays, but when I click on the layer to identify a polygon, the app closes. Have ye any idea why this is?
Many thanks in advance.
Shane
DanO_Neill
The Android API honors the JSON response from the service as an ArrayList. What is the return from a REST call on the service?  Try something like this on your service to confirm the return your service provides.
deleted-user-vpHnfyiCToFz
Has this been or is going to be resolved?  Anyone have a fix for honoring field order in the map service?
