Feature Layer. Disappearing points.
1521
04-09-2012 06:32 AM
InessaShammas
If ???Apply Edits??? method used on second Feature Layer, then after pausing and resuming the application, features load, but don???t appear.
public class BlablaESRIActivity extends Activity {
 public MapView mapView;
 BingMapsLayer tLayer = null;
 ArcGISFeatureLayer fLayer = null;
 ArcGISFeatureLayer logTable = null;
 Graphic currentGraphic = null;
    @Override
    public void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        requestWindowFeature(Window.FEATURE_NO_TITLE);
        setContentView(R.layout.main);
        mapView = (MapView)findViewById(R.id.mapview);
        mapView.setOnStatusChangedListener(mapOnStatusChangedListener);
        tLayer = new BingMapsLayer("vjhadbfabsdffv...", MapStyle.Road);
 mapView.addLayer(tLayer);
 mapView.setOnSingleTapListener(mapOnSingleTapListener);
 @Override
 protected void onDestroy() {
  super.onDestroy();
  mapView.recycle();
 @Override
 protected void onPause() {
  super.onPause();
  mapView.pause();
 @Override
 protected void onResume() {
  super.onResume();
  mapView.unpause();
 private OnStatusChangedListener mapOnStatusChangedListener = new OnStatusChangedListener() {
  private static final long serialVersionUID = 1L;
  public void onStatusChanged(Object source, STATUS status) {
   if (source == mapView && status == STATUS.INITIALIZED) {
        fLayer = new ArcGISFeatureLayer("http://.../ArcGIS/rest/services/POIs/FeatureServer/0",MODE.ONDEMAND);
               mapView.addLayer(fLayer);
              logTable = new ArcGISFeatureLayer("http://.../ArcGIS/rest/services/POIs/FeatureServer/1", new Options(),c);
 private OnSingleTapListener mapOnSingleTapListener = new OnSingleTapListener() {
  public void onSingleTap(float x, float y) {
   if (currentGraphic == null) {
          int[] graphicIDs = fLayer.getGraphicIDs(x, y, 20);
          if (graphicIDs == null) return;
          if (graphicIDs.length == 0) return;
          currentGraphic = fLayer.getGraphic(graphicIDs[0]);
   } else {
          Point p = (Point) currentGraphic.getGeometry();
          p.setXY(mapView.toMapPoint(x, y).getX(), mapView.toMapPoint(x, y).getY());
    saveCurrentPOI();
 public void saveCurrentPOI() {
  if (currentGraphic == null) return;
  fLayer.applyEdits(null, null, new Graphic[] { currentGraphic }, null);
  Map<String, Object> attributes = new HashMap<String, Object>();
  attributes.put("LANDMARK_NAME", "name");
  attributes.put("LANDMARK_X", ((Point) currentGraphic.getGeometry()).getX());
  attributes.put("LANDMARK_Y", ((Point) currentGraphic.getGeometry()).getY());
     Graphic newLogRecord = new Graphic(null, null, attributes, null);
     //If ???Apply Edits??? method used on this Feature Layer, then after pausing and resuming the application, fLayer points load, but don???t appear.
     logTable.applyEdits(new Graphic[] { newLogRecord }, null, null, null);
IainCampion
I had a similar issue with flex ....
when the edits where applied, the graphics disappeared ..
and had to create a new instance off the graphic that wasnt connected to the graphic layer and it kept the graphics on the screen in this function below ...... (instead of using the graphic input from the function)
hope this helps ..
private function FeatureOperation(graphic:Graphic, shapetype:String, operation:String):void
    if(operation == "add")
    ///test applying edits
    const attr:Object = {};
    var date:Date = new Date();
    //set attributes
    attr["BlastID"] = blastID.text;
    attr["DateCreated"] = date.time;     //1227663551096;
    attr["StartDate"] =  null;   ///1227663551096;
    attr["StartTime"] =  null;   ///1227663551096;
    attr["FinishDate"] = null;
    attr["FinishTime"] = null;
    attr["CreatedBy"] = null;
    attr["InnerBuffer"] = innerBuffer.text;
    attr["OuterBuffer"] = outerBuffer.text;
    attr["ShapeType"] = shapetype;
    attr["Status"] = 1 ; ///Domain: Coded Values: [1: Active], [2: Inactive], [3: Planned], ...1 more...)
    var g:Graphic = new Graphic(graphic.geometry,null,attr);
    ///graphic.attributes = attr;
    FeatureLayer(editfs).applyEdits( [ g ], null, null , true, new AsyncResponder(featureLayer_editsCompleteHandler, featureLayer_faultHandler));
