Failed to initialize the MapView.
2274
04-15-2012 11:02 PM
RafaelLuo
I ran the HelloWorld sample and got these log infomation.
[PHP]04-16 14:56:33.104: D/dalvikvm(9369): Late-enabling CheckJNI
04-16 14:56:33.134: I/dalvikvm(9369): Turning on JNI app bug workarounds for target SDK version 7...
04-16 14:56:33.234: D/ArcGIS.LifeCycle(9369): map.onChildViewAdded
04-16 14:56:33.244: D/ArcGIS.LifeCycle(9369): map.initLayer
04-16 14:56:33.244: D/ArcGIS.LifeCycle(9369): >>>layer init startcom.esri.android.map.ags.ArcGISTiledMapServiceLayer
04-16 14:56:33.244: D/ArcGIS.LifeCycle(9369): layer init...
04-16 14:56:33.244: W/dalvikvm(9369): VFY: unable to find class referenced in signature (Lorg/codehaus/jackson/JsonNode;)
04-16 14:56:33.244: I/dalvikvm(9369): Could not find method org.codehaus.jackson.JsonNode.get, referenced from method com.esri.android.a.e.a
04-16 14:56:33.244: W/dalvikvm(9369): VFY: unable to resolve virtual method 4781: Lorg/codehaus/jackson/JsonNode;.get (Ljava/lang/String;)Lorg/codehaus/jackson/JsonNode;
04-16 14:56:33.244: D/dalvikvm(9369): VFY: replacing opcode 0x6e at 0x0005
04-16 14:56:33.244: I/dalvikvm(9369): Could not find method org.codehaus.jackson.JsonNode.getTextValue, referenced from method com.esri.android.a.e.a
04-16 14:56:33.244: W/dalvikvm(9369): VFY: unable to resolve virtual method 4784: Lorg/codehaus/jackson/JsonNode;.getTextValue ()Ljava/lang/String;
04-16 14:56:33.244: D/dalvikvm(9369): VFY: replacing opcode 0x6e at 0x000b
04-16 14:56:33.244: E/HtcAppUsageStatsListener(9369): afterPerformResume
04-16 14:56:33.244: E/HtcAppUsageStatsListener(9369): java.lang.NullPointerException
04-16 14:56:33.244: E/HtcAppUsageStatsListener(9369):  at android.app.HtcAppUsageStatsListener.afterPerformResume(HtcAppUsageStatsListener.java:77)
04-16 14:56:33.244: E/HtcAppUsageStatsListener(9369):  at android.app.ActivityThread.performResumeActivity(ActivityThread.java:2800)
04-16 14:56:33.244: E/HtcAppUsageStatsListener(9369):  at android.app.ActivityThread.handleResumeActivity(ActivityThread.java:2851)
04-16 14:56:33.244: E/HtcAppUsageStatsListener(9369):  at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2234)
04-16 14:56:33.244: E/HtcAppUsageStatsListener(9369):  at android.app.ActivityThread.access$600(ActivityThread.java:139)
04-16 14:56:33.244: E/HtcAppUsageStatsListener(9369):  at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1261)
04-16 14:56:33.244: E/HtcAppUsageStatsListener(9369):  at android.os.Handler.dispatchMessage(Handler.java:99)
04-16 14:56:33.244: E/HtcAppUsageStatsListener(9369):  at android.os.Looper.loop(Looper.java:154)
04-16 14:56:33.244: E/HtcAppUsageStatsListener(9369):  at android.app.ActivityThread.main(ActivityThread.java:4944)
04-16 14:56:33.244: E/HtcAppUsageStatsListener(9369):  at java.lang.reflect.Method.invokeNative(Native Method)
04-16 14:56:33.244: E/HtcAppUsageStatsListener(9369):  at java.lang.reflect.Method.invoke(Method.java:511)
04-16 14:56:33.244: E/HtcAppUsageStatsListener(9369):  at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:784)
04-16 14:56:33.244: E/HtcAppUsageStatsListener(9369):  at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:551)
04-16 14:56:33.244: E/HtcAppUsageStatsListener(9369):  at dalvik.system.NativeStart.main(Native Method)
04-16 14:56:33.244: D/ArcGIS.TileCache(9369): max number of cached tiles:1000
04-16 14:56:33.244: D/ArcGIS.LifeCycle(9369): sdcache inited.
04-16 14:56:33.244: D/ArcGIS.TileCache(9369): SDCardCache
04-16 14:56:33.244: E/dalvikvm(9369): Could not find class 'org.codehaus.jackson.JsonFactory', referenced from method com.esri.core.internal.b.a.e.<clinit>
04-16 14:56:33.244: W/dalvikvm(9369): VFY: unable to resolve new-instance 717 (Lorg/codehaus/jackson/JsonFactory;) in Lcom/esri/core/internal/b/a/e;
04-16 14:56:33.244: D/dalvikvm(9369): VFY: replacing opcode 0x22 at 0x0000
04-16 14:56:33.244: W/dalvikvm(9369): VFY: unable to find class referenced in signature (Lorg/codehaus/jackson/JsonFactory;)
04-16 14:56:33.254: I/dalvikvm(9369): Could not find method org.codehaus.jackson.JsonFactory.createJsonParser, referenced from method com.esri.core.internal.b.a.e.a
04-16 14:56:33.254: W/dalvikvm(9369): VFY: unable to resolve virtual method 4760: Lorg/codehaus/jackson/JsonFactory;.createJsonParser (Ljava/io/InputStream;)Lorg/codehaus/jackson/JsonParser;
04-16 14:56:33.254: D/dalvikvm(9369): VFY: replacing opcode 0x6e at 0x016c
04-16 14:56:33.254: W/dalvikvm(9369): VFY: unable to resolve virtual method 4761: Lorg/codehaus/jackson/JsonFactory;.createJsonParser (Ljava/lang/String;)Lorg/codehaus/jackson/JsonParser;
04-16 14:56:33.254: D/dalvikvm(9369): VFY: replacing opcode 0x6e at 0x0022
04-16 14:56:33.254: D/dalvikvm(9369): VFY: replacing opcode 0x6e at 0x001f
04-16 14:56:33.254: D/dalvikvm(9369): DexOpt: unable to opt direct call 0x1296 at 0x02 in Lcom/esri/core/internal/b/a/e;.<clinit>
04-16 14:56:33.264: W/dalvikvm(9369): Exception Ljava/lang/NoClassDefFoundError; thrown while initializing Lcom/esri/core/internal/b/a/e;
04-16 14:56:33.274: D/ArcGIS(9369): Failed to initialize the MapView.
04-16 14:56:33.274: D/ArcGIS(9369): java.lang.ExceptionInInitializerError
04-16 14:56:33.274: D/ArcGIS(9369):  at com.esri.core.internal.a.a.k.a(Unknown Source)
04-16 14:56:33.274: D/ArcGIS(9369):  at com.esri.android.map.ags.ArcGISTiledMapServiceLayer.initModel(Unknown Source)
04-16 14:56:33.274: D/ArcGIS(9369):  at com.esri.android.map.LayerView.initLayer(Unknown Source)
04-16 14:56:33.274: D/ArcGIS(9369):  at com.esri.android.map.MapView$1.a(Unknown Source)
04-16 14:56:33.274: D/ArcGIS(9369):  at com.esri.android.map.MapView$1.call(Unknown Source)
04-16 14:56:33.274: D/ArcGIS(9369):  at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:305)
04-16 14:56:33.274: D/ArcGIS(9369):  at java.util.concurrent.FutureTask.run(FutureTask.java:137)
04-16 14:56:33.274: D/ArcGIS(9369):  at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1076)
04-16 14:56:33.274: D/ArcGIS(9369):  at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:569)
04-16 14:56:33.274: D/ArcGIS(9369):  at java.lang.Thread.run(Thread.java:864)
04-16 14:56:33.274: D/ArcGIS(9369): Caused by: java.lang.NoClassDefFoundError: org.codehaus.jackson.JsonFactory
04-16 14:56:33.274: D/ArcGIS(9369):  at com.esri.core.internal.b.a.e.<clinit>(Unknown Source)
04-16 14:56:33.274: D/ArcGIS(9369):  ... 11 more
04-16 14:56:33.274: D/ArcGIS.LifeCycle(9369): sdcard inited.
04-16 14:56:33.294: D/ArcGIS.LifeCycle(9369): map.onSizechanged
04-16 14:56:33.294: D/ArcGIS.LifeCycle(9369): !!! onSizeChangedSignal
04-16 14:56:33.294: D/ArcGIS.LifeCycle(9369): map.onLayout
04-16 14:56:33.304: D/ArcGIS.LifeCycle(9369): map.onLayout
04-16 14:56:33.314: D/memalloc(9369): /dev/pmem: Mapped buffer base:0x51fbc000 size:27017216 offset:24928256 fd:56
[/PHP]
I just update Android SDK 2 days before.
agosh
maybe you shoud target SDK version 8
open the "project.porperties" file, and make sure "target=android-8"
then save & run
AndyGup
@iwaitu make sure your SDK is installed properly. Check in Eclipse to make sure there are no errors in your project. For example, you may be missing one or several of the helper libraries:
[INDENT]Could not find class 'org.codehaus.jackson.JsonFactory'[/INDENT]
You may need to uninstall and re-install the ArcGIS for Android SDK.
-Andy
