Facing issue while syncing point to geodatabase
1080
06-05-2023 03:40 AM
komalzoting
Hii All,
I have loaded map using portal item. I want to sync point geodatabase but its showing error that is "Can only call this method on a loaded table."
code snippet is given bellow
// Loading map using portal item
val portal = Portal("https://arcgisruntime.maps.arcgis.com/")
val portalItem = PortalItem(portal, "fb788308ea2e4d8682b9c05ef641f273")
map = ArcGISMap(portalItem)
ServiceGeodatabase(service_layer_url).apply {
loadAsync()
addDoneLoadingListener {
// create a feature layer using the first layer in the geodatabase
serviceFeatureTable = getTable(0)
//  syncing point to database
private fun addFeature(mapPoint: Point, featureTable: ServiceFeatureTable) {
// create default attributes for the feature
hashMapOf<String, Any>(
"typdamage" to "Destroyed",
"primcause" to "Earthquake"
).let { attributes ->
// creates a new feature using default attributes and point
featureTable.createFeature(attributes, mapPoint)
}.let { feature ->
// check if feature can be added to feature table
if (featureTable.canAdd()) {
// add the new feature to the feature table and to server
featureTable.addFeatureAsync(feature).addDoneListener { applyEdits(featureTable) }
} else {
logToUser(true, getString(R.string.error_cannot_add_to_feature_table))
* Sends any edits on the ServiceFeatureTable to the server.
* @param featureTable service feature table
private fun applyEdits(featureTable: ServiceFeatureTable) {
// apply the changes to the server
featureTable.serviceGeodatabase.applyEditsAsync().let { editResult ->
editResult.addDoneListener {
try {
editResult.get()?.let { edits ->
// check if the server edit was successful
edits.firstOrNull()?.let {
if (!it.editResult[0].hasCompletedWithErrors()) {
logToUser(false, getString(R.string.feature_added))
} else {
it.editResult[0].error
} catch (e: ArcGISRuntimeException) {
logToUser(true, getString(R.string.error_applying_edits, e.cause?.message))
//error
com.esri.arcgisruntime.ArcGISRuntimeException: Invalid call.: Can only call this method on a loaded table.
at com.esri.arcgisruntime.internal.jni.CoreFeatureTable.nativeCreateFeatureWithAttributes(Native Method)
at com.esri.arcgisruntime.internal.jni.CoreFeatureTable.a(SourceFile:13)
at com.esri.arcgisruntime.data.FeatureTable.createFeature(SourceFile:4)
at com.example.identifypopup.MainActivity.addFeature(MainActivity.kt:616)
at com.example.identifypopup.MainActivity.onCreate$lambda$8(MainActivity.kt:281)
Please help
Shubham_Sharma
Based on your code seems like you are using the "Add features (feature service)" sample as your example code. To me the code seems right and might need some debugging based on the error message you received. "Invalid call.: Can only call this method on a loaded table."
Would recommend checking to see if the ServiceFeatureTable has been loaded before adding a point feature to the table:
val serviceFeatureTable = getTable(0)
if (serviceFeatureTable.loadStatus == LoadStatus.LOADED) {
// add point feature here...
} else if (serviceFeatureTable.loadStatus == LoadStatus.FAILED_TO_LOAD) {
logToUser(
true,
"Error loading service feature table: ${serviceFeatureTable.loadError.message}"
