Esri SDK with gradle build system
3855
12-27-2013 08:18 AM
ThomasBinu
Hi guys,
Is is possible to use the ArcGIS SDK using the new gradle build system?
Thomas
AndrewWang
Yes, for example if you are using Google's Android Studio, create a new folder called libs and copy over all the esri library files.
Then go into the build.gradle file and add in the lines:
dependencies {
    compile fileTree(dir: 'libs', include:'*.jar')
[ATTACH=CONFIG]30130[/ATTACH]
ThomasBinu
Thanks you Andrew. I noticed in your screenshots that, you have x86.jar and armebi.jar in your libs folder. How did you convert the .so files(that you get when you extract the sdk zip package) to .jar files?
thanks
Thomas
edit:Nevermind, I think I figured it out. I zipped the folder containing the .so files and changed the extension to .jar. But when i run the app, it crashes in the layout xml because of classdef not found error.
hungNguyen2
useful information. Thank you very much
