Esri is crashing when returning to Esri activity in android
2757
04-02-2019 03:07 AM
AhsanApp
2019-04-02 15:01:49.768 569-770/ E/AndroidRuntime: FATAL EXCEPTION: GLThread 10588
Process: PID: 569
com.esri.arcgisruntime.ArcGISRuntimeException: Invalid argument
at com.esri.arcgisruntime.internal.jni.CoreGeoView.nativeResize(Native Method)
at com.esri.arcgisruntime.internal.jni.CoreGeoView.a(SourceFile:581)
at com.esri.arcgisruntime.internal.h.b.g.a(SourceFile:1077)
at com.esri.arcgisruntime.mapping.view.GeoView$b.onSurfaceChanged(SourceFile:1308)
at android.opengl.GLSurfaceView$GLThread.guardedRun(GLSurfaceView.java:1555)
at android.opengl.GLSurfaceView$GLThread.run(GLSurfaceView.java:1270)
Tags (1)
AhsanApp
I stopped dismissing the map when the activity onstop() was calling and now its working fine. Thanks.
ChanganShi
Could you send us your XML layout file and a simple test case? On what device do you run into the crash?  Thanks!
AhsanApp
Yeah sure. Esri works fine when I first navigate to the Esri activity but when I return to Esri activity from any activity it gives the same crash every time as I stated earlier. I tested this on Samsung S8 and Samsung S9. Below is the xml file content.
<RelativeLayout
    android:id="@+id/relativeLayoutMap"
    android:layout_width="wrap_content"
    android:layout_height="wrap_content">
    <com.esri.arcgisruntime.mapping.view.MapView
        android:id="@+id/map"
        android:layout_width="match_parent"
        android:layout_height="match_parent"/>
    <LinearLayout
        android:id="@+id/linearlayoutMappOption"
        android:orientation="vertical"
        android:layout_width="160dp"
        android:layout_marginBottom="500dp"
        android:layout_margin="0dp"
        android:layout_alignParentBottom="true"
        android:layout_alignParentRight="true"
        android:visibility="visible"
        <ImageButton
            android:id="@+id/imageButtonLocate"
            android:layout_width="124dp"
            android:layout_height="58dp"
            android:layout_gravity="right"
            android:src="@mipmap/icon_map_locate"
            android:scaleType="fitCenter"
            android:layout_margin="1dp"
            android:background="@android:color/transparent"
        </ImageButton>
        <ImageButton
            android:id="@+id/imageButtonMapLayers"
            android:src="@mipmap/icon_map_layers"
        </ImageButton>
        <ImageButton
            android:id="@+id/dummy"
            android:layout_height="28dp"
        </ImageButton>
    </LinearLayout>
    <ProgressBar
        android:id="@+id/progressBarMap"
        android:layout_width="50dip"
        android:layout_height="50dip"
        android:layout_centerInParent="true"
        android:visibility="gone"
</RelativeLayout>
ChanganShi
We could not repo the crash based on the layout XML and navigate between two activities. Could you create a simple test-case for your workflow to repro the crash? thanks
AhsanApp
