Error performing submit job operation for Export Cache - Android SDK- EstimateTileCacheSizeJob
1180
11-14-2018 05:01 AM
InforEAM
I am using following code snippet to download basemap. But I am getting "Error performing submit job operation for Export Cache" error in vEstimateTileCacheSizeJob.addJobDoneListener(new Runnable() position. Can anybody pinpoint what might be the reason for this issue.
final ListenableFuture<ExportTileCacheParameters> vExportTileCacheParameterFuture = vExportTileCacheTask.createDefaultExportTileCacheParametersAsync(vExtentEnvelope, 0.0, 0.0);
vExportTileCacheParameterFuture.addDoneListener(new Runnable()
    @Override
    public void run()
        try
            final ExportTileCacheParameters vExportTileCacheParameters = vExportTileCacheParameterFuture.get();
            if(vExportTileCacheParameters == null)
            final EstimateTileCacheSizeJob vEstimateTileCacheSizeJob = vExportTileCacheTask.estimateTileCacheSizeAsync(vExportTileCacheParameters);
            vEstimateTileCacheSizeJob.setRequestConfiguration(getRequestConfiguration(300));
            // start the job to EstimateTileCacheSize
            mJobInProgress = vEstimateTileCacheSizeJob;
            vEstimateTileCacheSizeJob.start();
            vEstimateTileCacheSizeJob.addJobChangedListener(new Runnable() {
                @Override
                public void run() {
                @Override
                public void run()
                    if (vEstimateTileCacheSizeJob.getStatus() == Job.Status.SUCCEEDED)
                        EstimateTileCacheSizeResult vEstimateTileCacheSizeResult = vEstimateTileCacheSizeJob.getResult();
                        if(vEstimateTileCacheSizeResult == null)
                            handleSyncError("","An unknown error occured while estimating cache size.");
                            return;
                        Long vEstimatedFileSize = vEstimateTileCacheSizeResult.getFileSize();
                        updateLog("Estimated BaseMap File Size : " + String.valueOf(vEstimatedFileSize));
                        Long vAvailableFreeSpace = Environment.getExternalStorageDirectory().getFreeSpace();
                        updateLog("Available Device Free Space : " + String.valueOf(vAvailableFreeSpace));
                        if (vEstimatedFileSize >= 0 && vAvailableFreeSpace > vEstimatedFileSize)
                            // download base map
                            final String vBaseMapDestinationPath = DBAdmin.getBaseMapPath();
                            final ExportTileCacheJob vExportTileCacheJob = vExportTileCacheTask.exportTileCacheAsync(vExportTileCacheParameters, vBaseMapDestinationPath);
                            vExportTileCacheJob.setRequestConfiguration(getRequestConfiguration(600));
                            // start the job to Export TileCache
                            vExportTileCacheJob.start();
                            mJobInProgress = vExportTileCacheJob;
                            vExportTileCacheJob.addJobChangedListener(new Runnable() {
                                @Override
                                public void run() {
                            vExportTileCacheJob.addJobDoneListener(new Runnable()
                                @Override
                                public void run()
                                    if (vExportTileCacheJob.getStatus() == Job.Status.SUCCEEDED)
                                    else
                                        handleSyncError("An error occured while downloading the basemap: " + mJobInProgress.getError().getAdditionalMessage(), "Could not download the basemap.");
                        else
                            handleSyncError("", "Not enough space on device to download Basemap.");
                    else
                        handleSyncError("An error occured while estimating cache size: " + vEstimateTileCacheSizeJob.getError().getAdditionalMessage(), "An error occured while estimating cache size. Ensure that the Basemap is available and that the requested LODs and/or extent do not exceed the servers export tile limit.");
