Do I need an EDN License for developing with ArcGIS runtime sdk for Android?
5542
03-06-2016 06:59 PM
nagavijayasankaran
Do I need an EDN license for ArcGIS Runtime sdk - Android development?
EricBader
Honored Contributor
No EDN license is necessary to obtain the ArcGIS Runtime SDKs. Just check out Install and set up—ArcGIS Runtime SDK for Android | ArcGIS for Developers . And that's it!
Eric
EricBader
Honored Contributor
Eric
nagavijayasankaran
Thank you Eric!
Is this true for other run time sdks for example Java? It will be great if there is a reference about SDKs which do not require an active EDN license.
EricBader
Honored Contributor
Yes. The fact that an EDN subscription is NOT required is true for all ArcGIS Runtime SDKs, across the board.
