Im getting this Error when loading an ESRI map inside the Android Environment. This didn't happen with ESRI's .1 Alpha SDK, but it does happen with their 1.0.0 SDK.
I know it has something to do with the OpenGL lib, but can't seem to find a solution. I am running the Motorola Xoom Tablet with the latest Android environment.
Also Its using Fragments, so that might have something to do with it.
Here is my stack Dump
01-24 14:20:31.290: ERROR/AndroidRuntime(4370): FATAL EXCEPTION: main 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): java.lang.RuntimeException: Unable to start activity ComponentInfo{com.irad.GeoHome/com.irad.GeoHome.map.EsriMapWidget}: android.view.InflateException: Binary XML file line #13: Error inflating class com.esri.android.map.MapView 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:1818) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:1834) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at android.app.ActivityThread.access$500(ActivityThread.java:122) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1027) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at android.os.Handler.dispatchMessage(Handler.java:99) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at android.os.Looper.loop(Looper.java:132) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at android.app.ActivityThread.main(ActivityThread.java:4126) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at java.lang.reflect.Method.invokeNative(Native Method) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at java.lang.reflect.Method.invoke(Method.java:491) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:844) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:602) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at dalvik.system.NativeStart.main(Native Method) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): Caused by: android.view.InflateException: Binary XML file line #13: Error inflating class com.esri.android.map.MapView 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at android.view.LayoutInflater.createView(LayoutInflater.java:596) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at android.view.LayoutInflater.createViewFromTag(LayoutInflater.java:671) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at android.view.LayoutInflater.rInflate(LayoutInflater.java:724) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at android.view.LayoutInflater.inflate(LayoutInflater.java:479) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at android.view.LayoutInflater.inflate(LayoutInflater.java:391) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at com.irad.GeoHome.map.EsriMapFragment.onCreateView(EsriMapFragment.java:21) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at android.support.v4.app.FragmentManagerImpl.moveToState(FragmentManager.java:714) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at android.support.v4.app.FragmentManagerImpl.moveToState(FragmentManager.java:912) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at android.support.v4.app.FragmentManagerImpl.addFragment(FragmentManager.java:990) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at android.support.v4.app.FragmentActivity.onCreateView(FragmentActivity.java:257) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at android.view.LayoutInflater.createViewFromTag(LayoutInflater.java:660) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at android.view.LayoutInflater.rInflate(LayoutInflater.java:724) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at android.view.LayoutInflater.rInflate(LayoutInflater.java:727) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at android.view.LayoutInflater.inflate(LayoutInflater.java:479) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at android.view.LayoutInflater.inflate(LayoutInflater.java:391) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at android.view.LayoutInflater.inflate(LayoutInflater.java:347) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at com.android.internal.policy.impl.PhoneWindow.setContentView(PhoneWindow.java:245) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at android.app.Activity.setContentView(Activity.java:1786) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at com.irad.GeoHome.map.EsriMapWidget.onCreate(EsriMapWidget.java:155) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1050) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:1782) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): ... 11 more 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): Caused by: java.lang.reflect.InvocationTargetException 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at java.lang.reflect.Constructor.constructNative(Native Method) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at java.lang.reflect.Constructor.newInstance(Constructor.java:416) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at android.view.LayoutInflater.createView(LayoutInflater.java:576) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): ... 31 more 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): Caused by: java.lang.ExceptionInInitializerError 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at com.esri.android.map.MapView.a(Unknown Source) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at com.esri.android.map.MapView.<init>(Unknown Source) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): ... 34 more 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): Caused by: java.lang.ExceptionInInitializerError 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at com.esri.android.map.MapSurface.<clinit>(Unknown Source) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): ... 36 more 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): Caused by: java.lang.UnsatisfiedLinkError: Couldn't load GLMapCore: findLibrary returned null 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at java.lang.Runtime.loadLibrary(Runtime.java:425) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at java.lang.System.loadLibrary(System.java:554) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): at com.esri.android.map.Layer.<clinit>(Unknown Source) 01-24 14:20:31.290: ERROR/AndroidRuntime(4370): ... 37 more
catch(e){
if (newSub.getAttribute("slang").toLowerCase() != code_l.toLowerCase()) {
if (trLabelsHtml != "") {
var labelSname = "";
if(labelEle[i].querySelector("ul li:nth-child(1)").getAttribute("aria-hidden")){
labelSname = labelEle[i].querySelector("ul li:nth-child(1)").outerHTML;
labelEle[i].innerHTML = "";
labelEle[i].innerHTML = labelSname + trLabelsHtml;
catch(e){
/* V 2.0:3 = Store not translated reply id */
if(lingoRSXML.snapshotLength == 0){
if($scope.falseReplyID == "") {
$scope.falseReplyID = value;
/* Get translated Body of Replies/Comments */
var lingoRBXML = doc.evaluate(lingoRBExp, doc, null, XPathResult.UNORDERED_NODE_SNAPSHOT_TYPE, null);
for(var i=0;i 0) {
var attachDiv = rootElement.querySelector('div.lia-quilt-row-main').querySelector('div.custom-attachments');
if (attachDiv) {
attachDiv = attachDiv.outerHTML;
else if(rootElement.querySelector('div.lia-quilt-row-main').querySelectorAll('#attachments').length > 0){
if ("ForumTopicPage" == "BlogArticlePage") {
attachDiv = rootElement.querySelector('div.lia-quilt-row-main .lia-message-body-content').querySelector('#attachments');
if (attachDiv) {
else{
attachDiv = "";
}else{
attachDiv = rootElement.querySelector('div.lia-quilt-row-main').querySelector('#attachments').outerHTML;
else {
attachDiv = "";
/* Feedback Div */
var feedbackDiv = "";
var feedbackDivs = rootElement.querySelector('div.lia-quilt-row-main').querySelectorAll('div.lia-panel-feedback-banner-safe');
if (feedbackDivs.length > 0) {
for (var k = 0; k < feedbackDivs.length; k++) {
feedbackDiv = feedbackDiv + feedbackDivs[k].outerHTML;
else {
var attachDiv = rootElement.querySelector('div.lia-message-body-content').querySelector('div.Attachments.preview-attachments');
if (attachDiv) {
} else {
attachDiv = "";
/* Everyone tags links */
if (document.querySelectorAll("div.TagList").length > 0){
var everyoneTagslink = document.querySelector('div.lia-quilt-row-main').querySelector(".MessageTagsTaplet .TagList");
if ((everyoneTagslink != null)||(everyoneTagslink != undefined)){
everyoneTagslink = everyoneTagslink.outerHTML;
else{
everyoneTagslink = "";
/* Feedback Div */
var feedbackDivs = rootElement.querySelector('div.lia-message-body-content').querySelectorAll('div.lia-panel-feedback-banner-safe');
for (var m = 0; m < feedbackDivs.length; m++) {
feedbackDiv = feedbackDiv + feedbackDivs[m].outerHTML;
} catch (e) {
if (body_L == "") {
/* V 2.0:7 Replacing translated video data with source video data */
var newBodyVideoData = newBody.querySelectorAll('div[class*="video-embed"]');
angular.forEach($scope.videoData[value], function (sourceVideoElement, index) {
if (index <= (newBodyVideoData.length - 1)) {
newBodyVideoData[index].outerHTML = sourceVideoElement.outerHTML
/* V 2.0:7 = Replacing translated image data with source data */
var newBodyImageData = newBody.querySelectorAll('[class*="lia-image"]');
angular.forEach($scope.imageData[value], function (sourceImgElement, index) {
if (index <= (newBodyImageData.length - 1)) {
newBodyImageData[index].outerHTML = sourceImgElement.outerHTML;
/* V 2.0:7 = Replacing translated pre tag data with source data */
var newBodyPreTagData = newBody.querySelectorAll('pre');
angular.forEach($scope.preTagData[value], function (sourcePreTagElement, index) {
if (index <= (newBodyPreTagData.length - 1)) {
newBodyPreTagData[index].outerHTML = sourcePreTagElement.outerHTML;
var copyBodySubject = false;
if (body_L == "") {
copyBodySubject = true;
body_L = newBody.innerHTML;
/* This code is written as part of video fix by iTalent */
/* try{
var iframeHTMLText = body_L;
var searchIframeText = "<IFRAME";
var foundiFrameTag;
if (iframeHTMLText.indexOf(searchIframeText) > -1) {
foundiFrameTag = decodeHTMLEntities(iframeHTMLText);
foundiFrameTag = foundiFrameTag.split('src="')[1];
body_L = foundiFrameTag;
catch(e){
/* This code is placed to remove the extra meta tag adding in the UI*/
try{
body_L = body_L.replace('<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />','');
catch(e){
/** We should not replace the source content if user profile language and selected target language matches with source language **/
if(showTrContent) {
var compiled = false;
rootElement.querySelectorAll('div.lia-message-body-content')[0].innerHTML = null
if("ForumTopicPage"=="IdeaPage"){
// var customAttachDiv = '';
rootElement.querySelectorAll('div.lia-message-body-content')[0].innerHTML = body_L + feedbackDiv ;
$compile(rootElement.querySelectorAll('div.lia-message-body-content')[0])($scope);
compiled = true;
/* Attach atttach div */
// document.querySelector("div.translation-attachments-"+value).innerHTML = attachDiv;
rootElement.querySelectorAll('div.lia-message-body-content')[0].insertAdjacentHTML('afterend',attachDiv);
if(rootElement.querySelectorAll('div.lia-quilt-idea-message .lia-message-body .lia-attachments-message').length > 1){
rootElement.querySelectorAll('div.lia-quilt-idea-message .lia-message-body .lia-attachments-message')[1].remove();
} else {
if("ForumTopicPage"=="TkbArticlePage"){
}else{
rootElement.querySelectorAll('div.lia-message-body-content')[0].innerHTML = body_L + feedbackDiv + attachDiv;
compiled = true;
/* Destroy and recreate OOyala player videos to restore the videos in target languages which is written by iTalent as part of iTrack LILICON-79 */ /* Destroy and recreate OOyala player videos */
try{
// $scope.videoData[value][0].querySelector("div").getAttribute("id");
for(var vidIndex=0; vidIndex<$scope.videoData[value].length; vidIndex++){
if( $scope.videoData[value][vidIndex].querySelector("div") != null){
var containerId = LITHIUM.OOYALA.players[$scope.videoData[value][vidIndex].querySelector("div").getAttribute("id")].containerId;
videoId = LITHIUM.OOYALA.players[$scope.videoData[value][vidIndex].querySelector("div").getAttribute("id")].videoId;
/** Get the Video object */
vid = OO.Player.create(containerId,videoId);
/** Destroy the video **/
vid.destroy();
/** recreate in the same position */
var vid = OO.Player.create(containerId,videoId);
catch(e){
try{
for(var vidIndex=0; vidIndex<($scope.videoData[value].length); vidIndex++){
if($scope.videoData[value][vidIndex].querySelector('video-js') != null){
var data_id = $scope.videoData[value][vidIndex].querySelector('video-js').getAttribute('data-video-id');
var data_account = $scope.videoData[value][vidIndex].querySelector('video-js').getAttribute('data-account');
var data_palyer = $scope.videoData[value][vidIndex].querySelector('video-js').getAttribute('data-player');
var div = document.createElement('div');
div.id = "brightcove";
div.class = "brightcove-player";
div.innerHTML =
'(view in my videos)'
var data = div.getElementsByClassName("video-js");
var script = document.createElement('script');
script.src = "https://players.brightcove.net/" + data_account + "/" + data_palyer + "_default/index.min.js";
for(var i=0;i< data.length;i++){
videodata.push(data[i]);
for(var i=0;i< videodata.length;i++){
document.getElementsByClassName('lia-vid-container')[i].innerHTML = videodata[i].outerHTML;
document.body.appendChild(script);
catch(e){
if(!compiled){
/* Re compile html */
if (code_l.toLowerCase() != newBody.getAttribute("slang").toLowerCase()) {
/* Adding Translation flag */
var tr_obj = $filter('filter')($scope.sourceLangList, function (obj_l) {
return obj_l.code.toLowerCase() === newBody.getAttribute("slang").toLowerCase()
if (tr_obj.length > 0) {
tr_text = "Esri may utilize third parties to translate your data and/or imagery to facilitate communication across different languages.".replace(/lilicon-trans-text/g, tr_obj[0].title);
try {
if ($scope.wootMessages[$rootScope.profLang] != undefined) {
tr_text = $scope.wootMessages[$rootScope.profLang].replace(/lilicon-trans-text/g, tr_obj[0].title);
} catch (e) {
} else {
//tr_text = "This message was translated for your convenience!";
tr_text = "Esri may utilize third parties to translate your data and/or imagery to facilitate communication across different languages.";
try {
if (!document.getElementById("tr-msz-" + value)) {
var tr_para = document.createElement("P");
tr_para.setAttribute("id", "tr-msz-" + value);
tr_para.setAttribute("class", "tr-msz");
tr_para.style.textAlign = 'justify';
var tr_fTag = document.createElement("IMG");
tr_fTag.setAttribute("class", "tFlag");
tr_fTag.setAttribute("src", "/html/assets/langTrFlag.PNG");
tr_fTag.style.marginRight = "5px";
tr_fTag.style.height = "14px";
tr_para.appendChild(tr_fTag);
var tr_textNode = document.createTextNode(tr_text);
tr_para.appendChild(tr_textNode);
/* Woot message only for multi source */
if(rootElement.querySelector(".lia-quilt-forum-message")){
rootElement.querySelector(".lia-quilt-forum-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-message-view-blog-topic-message")) {
rootElement.querySelector(".lia-message-view-blog-topic-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-quilt-blog-reply-message")){
rootElement.querySelector(".lia-quilt-blog-reply-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-quilt-tkb-message")){
rootElement.querySelector(".lia-quilt-tkb-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-quilt-tkb-reply-message")){
rootElement.querySelector(".lia-quilt-tkb-reply-message").insertBefore(tr_para,rootElement.querySelector(".lia-quilt-row.lia-quilt-row-footer"));
} else if(rootElement.querySelector(".lia-quilt-idea-message")){
rootElement.querySelector(".lia-quilt-idea-message").appendChild(tr_para);
} else if(rootElement.querySelector('.lia-quilt-occasion-message')){
rootElement.querySelector('.lia-quilt-occasion-message').appendChild(tr_para);
else {
if (rootElement.querySelectorAll('div.lia-quilt-row-footer').length > 0) {
rootElement.querySelectorAll('div.lia-quilt-row-footer')[0].appendChild(tr_para);
} else {
rootElement.querySelectorAll('div.lia-quilt-column-message-footer')[0].appendChild(tr_para);
} catch (e) {
} else {
/* Do not display button for same language */
// syncList.remove(value);
var index = $scope.syncList.indexOf(value);
if (index > -1) {
$scope.syncList.splice(index, 1);
/* V 1.1:2 = Reply Sync button for multi source translation */
} catch(e){
console.log(e);
if((rContent != undefined) && (rContent != "")) {
drawCanvas(decodeURIComponent(rContent));
/** Update variable with selected language code **/
$scope.previousSelCode = code_l;
* @function manageTranslation
* @description Managess the translation of given language for the thread
* @param {string} langCode - Language Code
* @param {string} tid - Thread ID
$scope.manageTranslation = function (langCode, tid) {
//debugger;
$scope.showTrText = false;
/* V 2.0:5 = actualStatus variable introduced to indicate detailed connector status on UI. This variable holds the actual translation percentage */
$scope.transPercent = "";
$scope.actualStatus = "";
if (tid != "") {
var bulkTranslation = lithiumPlugin.bulkTranslation(langCode, tid);
bulkTranslation.then(function (trContent) {
if(trContent.body != "") {
$scope.showPreview(trContent.body, $scope.mszList, langCode);
if(langCode != "en-US") {
$scope.showTrText = true;
if((trContent.status != "NA") && trContent.status != null) {
// $scope.transPercent = String(trContent.status);
$scope.actualStatus = String(trContent.status);
} else {
// $rootScope.errorMsg = "Translation is in progress. Please check again a few minutes."
$rootScope.errorMsg = "Translation is in progress. Please retry in a few minutes."
$scope.workbench = trContent.wb;
/* V 2.0:4 = Trigger uncalled or delayed callbacks (documnet uploaded/translation completed from lithium).*/
if(trContent.callback == 'true') {
var trCompletCallback = lithiumPlugin.trCompletCallback(langCode, trContent.docID);
trCompletCallback.then(function (callback){
// $rootScope.errorMsg = "Downloading Translated content in " + langCode + " now. Please check again in a few minutes."
$rootScope.errorMsg = "Uploading content to translate. Please check again in a few minutes."
} else if (trContent.callback == 'upload') {
var trCompletUpload = lithiumPlugin.trCompletUpload(langCode, trContent.docID);
trCompletUpload.then(function (callback) {
//$rootScope.errorMsg = "Uploading content to translate. Please check again in a few minutes."
} else if ("many" == "one") {
$scope.updateOOS();
} else if("SmartConx" == "SmartConx"){
if ("many" == "many"){
$scope.updateOOS();
}else if ((trContent.status != null) && trContent.status.includes("100")) {
/* If everything fine then only check Out of Sync status */
$scope.updateOOS();
} else {
/* If translation perccent is less than 100 then show the percentage on UI */
$scope.transPercent = $scope.actualStatus;
* @function selectThisLang
* @description Called on select dropdown.
* @param {string} lang - Language code
$scope.selectThisLang = function (lang, anonymousFlag) {
/* 1.4:3 Update Analytics on language selection */
try {
lingoThreadLangSelected(lang, '751828');
} catch (e) {
/** Display Translated content **/
var getTranslation = lithiumPlugin.getTranslation(lang, "751828");
getTranslation.then(function (trContent) {
if (trContent.body != "") {
$scope.showPreview(trContent.body, $scope.mszList, lang);
} else {
//$rootScope.errorMsg = "Translation is in progress. Please check again in a few minutes."
var decodeEntities = (function() {
// this prevents any overhead from creating the object each time
var element = document.createElement('div');
function decodeHTMLEntities (str) {
if(str && typeof str === 'string') {
// strip script/html tags
str = str.replace(/
