ArcGISDynamicMapServiceLayer alternative in API 100
1979
12-08-2016 12:29 PM
SharjeelAhmed
Previously I used following code for adding Layers:
UserCredentials userCredentials = new UserCredentials();
userCredentials.setUserAccount("Username", "Password");
dynamicLayer = new ArcGISDynamicMapServiceLayer(url,null, userCredentials, true);
mMapView.addLayer(dynamicLayer);
What's the alternative of adding ArcGISDynamicMapServiceLayer in API 100 as this Layer class doesn't exist in new API?
AlexanderNohe1
Honored Contributor
I believe you want to use the ArcGISMapImageLayer:
ArcGISMapImageLayer| arcgis-android
Have you tried using this?  Does it work for you?
AlexanderNohe1
Honored Contributor
SharjeelAhmed
That worked. Thanks.
