arcgis-android-100.11.0, Android 12/S Runtime Error
2753
05-07-2021 01:58 AM
DVBernMRRA
We are in the process of upgrading our app for the Android 12/S Preview.
Any call made to the ArcGisRuntimeEnvironment crashes the app.
We were able to reproduce the error in the tutorial provided here.
How to reproduce:
1. Set compileSdkVersion and targetSdkVersion to Android 12:
android {
    compileSdkVersion
"android-S"
    defaultConfig
        targetSdkVersion
"S"
2. Run the app
The error varies but the cause stays the same:
Caused by: java.lang.UnsatisfiedLinkError: dlopen failed: library "libc++_shared.so" not found
Anyone else encountered this ? How to proceed?
Edit 1, 11.05.21:
It seems this is an emulator only issue, we got it
working on pixel 3a with Android 12 Developer Preview 3.
Emulator still breaks with no avail.
Tags (5)
DVBernMRRA
Hello Rama
It was x86_64bit and somehow I am not able to download the x86 image.
But I found a solution by following this: https://developer.android.com/games/optimize/64-bit
and packaging the library's 64bit version into the APK by adding:
ndk.abiFilters 'x86','x86_64'
to my build.gradle file.
This is ofc just a solution for development and testing purposes, unless the app is actually intended to work on 64bit architecture. It would bloat the apk unnecessarily otherwise.
I will mark this issue as resolved.
RamaChintapalli
Can you check the CPU architecture of the emulator with Android S preview. Runtime currently only provides the native libs for arm64-v8a, armeabi-v7a and x86.
Thanks
Rama
DVBernMRRA
Hello Rama
