Android Sample, OfflineEditor, Error Sync(Error in uploading Changes)
7610
12
02-21-2015 02:51 PM
NabeelAdnan
Hello,
I am using offline editor sample for android, it working fine, but once i did any change and touch the Sync button to sync back(upload) my changes i faced the following Error
GDBUtil﹕ com.esri.core.io.EsriServiceException: Error in uploading item part ife0ef5ed-d728-4727-a9d9-a450d8147846
            at com.esri.core.internal.io.handler.c.a(SourceFile:613)
            at com.esri.core.internal.io.handler.h.a(SourceFile:288)
            at com.esri.core.internal.tasks.ags.aq.a(SourceFile:129)
            at com.esri.core.internal.tasks.ags.aq.a(SourceFile:56)
            at com.esri.core.internal.tasks.ags.aq.execute(SourceFile:35)
            at com.esri.core.internal.tasks.a.call(SourceFile:88)
            at com.esri.core.tasks.geodatabase.GeodatabaseSyncTask.submitUploadForSyncJobInternal(SourceFile:693)
            at com.esri.core.tasks.geodatabase.GeodatabaseSyncTask.access$1000(SourceFile:60)
            at com.esri.core.tasks.geodatabase.GeodatabaseSyncTask$2.call(SourceFile:290)
            at com.esri.core.tasks.geodatabase.GeodatabaseSyncTask$2.call(SourceFile:258)
            at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:305)
            at java.util.concurrent.FutureTask.run(FutureTask.java:137)
            at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1076)
            at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:569)
            at java.lang.Thread.run(Thread.java:856)
anyone has any idea how to come over this?
thank you in advance.
MengyiGuo
Are you working with Esri's sample feature service or your own service?
Would you like to provide more information about the steps to repro this issue? I worked as follows and it works fine:
1. Download data with the download button
2. Edit on local data with the edit button, choose an symbol from template, add the symbol to the map.
3. Touch the check button to finish editing.
4. Sync back with the Sync button, agree to delete previously downloaded geodatabase.
NabeelAdnan
Dear Sir,
Thank you for your response.
I am using Esri's sample feature service, and i am doing the following
3. Save your edit by clicking on Save button.
4. upload your edit by click on Sync Button
app will try to sync and then it will show the error.
MengyiGuo
If I understand correctly, is this your steps to repro the case?
NabeelAdnan
Yes Sir, i am doing 1, then add line or point then press 2, then my line gave me a feeling like it is saved in a file, and when i check the ARCGIS\samples\offlineEditor folder in my phone, i found some new files like offlinedata.geodatabase
after that i click on 3 and the message appears
Error in uploading item part <some random number here>
MengyiGuo
I'm following a same workflow but can not reproduce your issue... it seems that editing works but can not upload. How is your network?
NabeelAdnan
Yes Sir,
that is true, you can edit, and you can go online, and when you go offline again everything works fine, and you can find your edits, but once you click on Sync, to upload your work, a toast message appears on the phone says: Error in uploading item part <some random number here> and the following exception appears in the android studio(if ur phone is connected)
My Connection is good, i am using a 8 MB speed connection.
appreciate your help.
NabeelAdnan
Hello,
Any Updates?
MengyiGuo
It seems that we are following a same workflow but I can not reproduce your issue.
Would you like to try to delete the data folder(include the geodatabase parts) on your device and run it again? I doubt there is something wrong with the item part.
BenjaminBell
I have been running into this same issue.  I'm not using the ESRI sample data, however I have taken from the GBDUtil sample code.  It looks like it is having an issue with the Sync Parameters it gets from the gdb however I'm uncertain.
Error received below -
com.esri.core.io.EsriServiceException: Error in uploading item part i564909e3-5dc5-4315-bc0c-5307b2d40d5b
Code getting parameters -
final SyncGeodatabaseParameters syncParams = gdb.getSyncParameters();
Is there a way to create the sync parameters without grabbing them?
I'm using the latest Android Studio along with 10.2.5.
Any help is appreciated.
