RequestCredentials not found when using @esri/arcgis-rest-request
1106
05-10-2024 12:42 AM
Cmeng
Hi there,
I am building an node js application using typescript 5.4.5 and i am using @esri/arcgis-rest-request to try to get the access token from acrgis.
But i am hit with
node_modules/@esri/arcgis-rest-request/dist/esm/utils/IAuthenticationManager.d.ts:36:41 - error TS2304: Cannot find name 'RequestCredentials'.
and also
node_modules/@esri/arcgis-rest-request/dist/esm/utils/ITokenRequestOptions.d.ts:7:21 - error TS2552: Cannot find name 'RequestInfo'. Did you mean 'RequestInit'?
when i am trying to import 'request' from the module.
I wanted to ask if there is anyway to fix this? I have tried downgrading my typescript version to 4.2.x and 4.5.x but to no avail.
Any help or advice is greatly appreciated.
Thanks in advance.
GavinRehkemper
Hi @Cmeng, in order to help assist you, could you please post a minimal replication case that demonstrates the issue, so I'm able to run it and see your issue? Then I'll be able to look into it and we can hopefully get it resolved for you. Thank you!
