What is the JSON syntax for 'input geometry' through the REST / services directory?
10196
03-04-2014 01:30 PM
MatthewBaker2
Hi all,
Simple question,
When using the 'input geometry' box on the REST endpoint of a map service, what is the syntax of the JSON that goes into that box?
...I'm just trying to figure out what the return fields would be when I eventually pass in the XY of a geocode result...
Thanks!
-m
BjornSvensson
Esri Alum
The REST API documentation for the Map Service Query at
http://resources.arcgis.com/en/help/arcgis-rest-api/#/Query_Map_Service_Layer/02r3000000p1000000/ has examples like
{xmin: -104, ymin: 35.6, xmax: -94.32, ymax: 41}
The full details about the JSON geometry objects are at http://resources.arcgis.com/en/help/arcgis-rest-api/#/Geometry_Objects/02r3000000n1000000/.
BjornSvensson
Esri Alum
MatthewBaker2
Perfect! Thank you, Bjorn!
