Very simple REST API to arcgisonline  not working
3916
01-22-2014 06:45 AM
EkaitzHernandez
Hi All!
This request is not working:
http://www.arcgis.com/sharing/rest/community/groups/ad08050c3ada4be0a1a845251dcdb8c1
What is happening?
I receive a html code in the response:
[ATTACH=CONFIG]30712[/ATTACH]
[HTML]
<html>
   <head>
      <meta content="HTML Tidy for Java (vers. 26 Sep 2004), see www.w3.org" name="generator"/>
      <title>ArcGIS Portal Directory</title>
      <link type="text/css" rel="stylesheet" href="https://community.esri.com/sharing/rest/files/gw.css"/>
   </head>
   <body>
      <br/>
      <div class="gwDiv">
         <table width="100%" class="navTable">
            <tr>
               <td class="breadcrumbs">ArcGIS Portal Directory</td>
            </tr>
         </table>
         <br/>
         <br/>
         <b>
            <a href="https://community.esri.com/apidocs/rest">API Reference</a>
         </b>
         <table>
            <tr valign="top">
               <td/>
            </tr>
         </table>
      </div>
   </body>
</html>
[/HTML]
Thank you!
Noah-Sager
Hi Ekaitz,
When I sign-in to ArcGIS Online and try to access the item, I get this error:
[ATTACH=CONFIG]30713[/ATTACH]
I think the issue is that the item is not shared or publicly accessible. Please check your settings.
Is this a webmap or a web application? Can you view it without signing-in to ArcGIS Online?
If I add "?f=json" to the end of your URL, I see this:
[ATTACH=CONFIG]30714[/ATTACH]
It seems to be accessible to the public, but I still feel there is something not working with it if I cannot access it either. After checking your settings, I would also try publishing the item again.
-Noah
