Vector tile basemap not printing
11351
12
11-04-2019 11:58 AM
BryanBaker
I'm unable to get vector tile basemaps to print. Even with a very simple request that only includes the vector tile data, the request succeeds, but the map is blank and the vector tile basemap does not print. The request includes a very long imageData string, which is how I take it that the vector tile printing is handled. The request is being sent from the JavaScript API version 3.29.
I've tried printing the standard Esri topo-streets and topo-vector services, as well as the Esri OSM-vector service (added as a custom basemap).
If I capture the Web Map as JSON from the browser debugger and use it directly in the print service REST (services directory) form, I get the same result. I've tried the print with print services at version 10.7.1, both a standard print service and a custom service created in ArcGIS Pro. I've also tried it in the sample print service at http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer. I understand vector tile printing was supported as of 10.6.
I've attached a Web Map as JSON string that I've tested, which includes data from the topo-vector service as generated by the JavaScript API. Any ideas or suggestions on how to debug the request are appreciated.
by Anonymous User
Not applicable
Thank you Kory, I subscribed. It's present on 3.33. I saw it says Modified date yesterday in the bug doc. I am wondering if maybe it will be addressed in 3.34. I'll test each release and report back and thank you.
DavidColey
MVP Frequent Contributor
This is an old thread, but for those of you that are still interested this is still occurring at 4.x (4.22), at least when using @RobertScheitlin__GISP  's print widget in the ExB dev edition 1.7 in Chrome and Edge . . .
Thought you might want to know @Anonymous User
CharlottePeters95540
Hopefully, this will help troubleshoot the issue further. I was having export issues where I customized an ESRI basemap using the ArcGIS Vector Tile Style Editor and it wouldn't print or export on any maps from ArcGIS Pro v. 3.2. I fixed my issue by signing into my ESRI account within ArcGIS Pro.
