Update Features Using REST
6525
8
09-21-2018 11:01 AM
joerodmey
Right now I'm trying to do an update on particular ObjectIDs using Integromat and REST. Right now my JSON that I'm pushing to REST is as follows:
"attributes" : {
"OBJECTID" : 1,
"City_Name" : "here"}
Within Integromat I'm automatically grabbing the token and service URL so that should be correct. In the end I can update the feature using REST directly on the service URL page, but not successful with the Integromat method.
Any ideas?
joerodmey
Token was fine. Used apply edits instead
joerodmey
How to handle an invalid token response?
RandyBurton
It is possible the token has expired.  But it is more likely that you do not appear to be the same user when the token is pasted into Integromat.
joerodmey
Conor_McIntosh
Hi Joe,
Sorry to drag this up again.
I am going through the same thing you have done, where I would like Survey123 results to update the attributes of another hosted feature layer within AGOL.
Using Integromat I am successfully getting service URL and tokens as you have, I have tried both updatefeatures and applyedits to no avail. I am using the same JSON structure as you:
"attributes" : {
"OBJECTID" : 2,
"CORPORATE_NAME" : "this"}
Neither approach is working, are you able to provide any insight into the configuration of Integromat you are using that is allowing this to work?
Any help would be much appreciated!
If easier my email is [email protected]
Cheers,
Conor
joerodmey
Hi Conor,
Do you have a screenshot of your integromat setup?
PaulSolsrud
Hi, did you ever get Integromat OAuth set up? I can't seem to get the token request to work properly. Ideas?
Conor_McIntosh
Hi Paul, did you get an email response from me? If need be I can send you some screenshots of the workflow I used to get this working and hopefully that will help get it setup at your end!
BraundtSin-KiLau
Hi I'm also developing a widget on Experience Builder to upload a csv and update the features.
Am wondering if this REST api update would work in Javascript application? Thanks!
