Unhandled error when calling FeatureTable.QueryFeaturesAsync
509
12-14-2022 02:26 PM
BobTaylor
I have a question about the FeatureTable.QueryFeaturesAsync method call in the ArcGISRuntime toolkit sdk for .NET. I am calling this method from a WPF application. Sometimes, in our production environment, our application will crash after the method is called. The stack trace is :
System.Net.InternalException: System error.
at System.Net.HttpWebRequest.SetAndOrProcessResponse(Object responseOrException)
at System.Net.ConnectionReturnResult.SetResponses(ConnectionReturnResult returnResult)
at System.Net.Connection.ReadComplete(Int32 bytesRead, WebExceptionStatus errorStatus)
at System.Net.LazyAsyncResult.Complete(IntPtr userToken)
at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken)
at System.Net.Security._SslStream.ProcessFrameBody(Int32 readBytes, Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.Security._SslStream.ReadFrameCallback(AsyncProtocolRequest asyncRequest)
at System.Net.AsyncProtocolRequest.CompleteRequest(Int32 result)
at System.Net.FixedSizeReader.CheckCompletionBeforeNextRead(Int32 bytes)
at System.Net.FixedSizeReader.ReadCallback(IAsyncResult transportResult)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Net.ContextAwareResult.Complete(IntPtr userToken)
at System.Net.Sockets.BaseOverlappedAsyncResult.CompletionPortCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* nativeOverlapped)
at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)
We believe that a service disconnect is happening during the method call.
Our application has error handling around the call but does not catch the exception.
Does the QueryFeatureAsync method handle this type of error?
