Silverlight Maptips - maptiphidedelay ignored
1750
5
08-18-2010 02:25 PM
lyndamccallum
I currently have maptips on my silverlight application. The maptip over my selected feature ignores the MapTipHideDelay property. It disappears the sec I move my mouse, not giving me enough time to click the link on the maptip. Any ideas why this is happening for this one case or how this can be resolved?
dotMorten_esri
Esri Notable Contributor
Where did you specify the maptip? It has to be on the root element of the maptip element (not on the layer, or map or a sub element of that).
lyndamccallum
here's what my xaml look like:
   <esri:Map.Layers>
            <esri:ArcGISDynamicMapServiceLayer ID="BaseLayer" Url="{StaticResource WDPurl}"></esri:ArcGISDynamicMapServiceLayer>
                <esri:GraphicsLayer  ID="MyGraphicsLayer">
                </esri:GraphicsLayer>
                <esri:FeatureLayer ID="MyFeatureLayer" Url="{StaticResource FacilitiesLayerID}"  FeatureSymbol="{StaticResource DefaultNoMarkerSymbol}"  >
                    <esri:FeatureLayer.OutFields>
                        <sys:String>FACILITYNAME</sys:String>
                        <sys:String>SITEFROM</sys:String>
                        <sys:String>SITESTREET</sys:String>
                        <sys:String>SITEDIRECTION</sys:String>
                        <sys:String>SITECITY</sys:String>
                        <sys:String>FACILITYNUMBER</sys:String>
                    </esri:FeatureLayer.OutFields>
                    <esri:FeatureLayer.MapTip>
                        <Border esri:GraphicsLayer.MapTipHideDelay="00:00:01.5" Style="{StaticResource CommonBorder}" Padding="10,3,10,3"  Effect="{StaticResource dropShadow}" >
                            <StackPanel Orientation="Vertical" Margin="20,15,20,15">
                                <StackPanel Orientation="Horizontal" Margin="0,0,0,6">
                                    <TextBlock Text="Name: " FontWeight="Bold" Foreground="#FF0F274E" FontSize="12" />
                                    <TextBlock Text="{Binding Converter={StaticResource MyDictionaryConverter},
                                        ConverterParameter=FACILITYNAME, Mode=OneWay}" Foreground="#FFFFFFFF" FontSize="12" FontFamily="Portable User Interface" />
                                 </StackPanel>
                                    <TextBlock Text="Address: " FontWeight="Bold" Foreground="#FF0F274E" FontSize="12" />
                                        ConverterParameter=SITEFROM, Mode=OneWay}" Foreground="#FFFFFFFF" FontSize="12" FontFamily="Portable User Interface" />
                                    <TextBlock Text=" " />
                                        ConverterParameter=SITESTREET, Mode=OneWay}" Foreground="#FFFFFFFF" FontSize="12" FontFamily="Portable User Interface" />
                                        ConverterParameter=SITEDIRECTION, Mode=OneWay}" Foreground="#FFFFFFFF" FontSize="12" FontFamily="Portable User Interface" />
                                </StackPanel>
                                    <TextBlock Text="***************" FontWeight="Bold" Foreground="#FF0F274E" FontSize="12" />
                                        ConverterParameter=SITECITY, Mode=OneWay}" Foreground="#FFFFFFFF" FontSize="12" FontFamily="Portable User Interface" />
                                </StackPanel>
                                <StackPanel>
                                    <!--<TextBlock  Text="Inspection Results" Name="InspectionTextBlock"  Cursor="Hand" TextDecorations="Underline" MouseLeftButtonDown="InspectionTextBlock_MouseLeftButtonDown" Foreground="#FF0F274E" FontSize="12"/>-->
                                    <!--<HyperlinkButton x:Name="InspectionHyperlinkButton" TargetName="_blank" Content="{Binding Converter={StaticResource MyDictionaryConverter},ConverterParameter={StaticResource InspectionPage}}" NavigateUri="{Binding Converter={StaticResource MyDictionaryConverter},ConverterParameter={StaticResource InspectionPage}}"  ></HyperlinkButton>-->
                                    <HyperlinkButton x:Name="InspectionHyperLinkButton" TargetName="_blank" Content ="Inspection Report" NavigateUri="{Binding Converter={StaticResource UriConverter1}, ConverterParameter=FACILITYNUMBER}" Foreground="#FF0F274E"  FontSize="12"/>
                                </StackPanel>
                               </StackPanel>
                        </Border>
                    </esri:FeatureLayer.MapTip>
                </esri:FeatureLayer>
            </esri:Map.Layers>
lyndamccallum
Nope, still looking for a solution
AntonHughes
I also have the same problem.
Anyone have a fix?
lyndamccallum
Just solved this yesterday. It was because I had a Graphiclayer and a featurelayer ontop of each other. The featurelayer with the maptips with intially set to false and I  had choosen a random symbol for it's dispaly. The problem was that my graphiclayer used another symbol. The trick was to make sure the maptips layer uses the same symbol as the graphiclayer. Then everything worked.
